BT.com
Wishlist
Fujitsu 8GB DDR4 DIMM 288-pin 2133 MHz/PC4-17000 1.2V Unbuffered ECC
Fujitsu 8GB DDR4 DIMM 288-pin 2133...
£116.00
£116.00
Add to wishlist
Delivery
Standard 1-3 working days
For PRIMERGY RX1330 M2, TX1320 M2, TX1330 M2
Fujitsu - DDR4 - 8 GB - DIMM 288-pin
RAM memory
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Dual rank, unbuffered
Voltage
1.2 V
Fujitsu S26361-F3909-L515
8 GB
Upgrade Type
System specific
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
ECC
Chips Organization
X8
Voltage
1.2 V
Fujitsu PRIMERGY RX1330 M2, TX1320 M2, TX1330 M2
Scroll to top
