BT.com
Wishlist
Fujitsu 8GB (1 x 8GB) Memory Module 2rx8 L DDR3 1600MHz ECC
Fujitsu 8GB (1 x 8GB) Memory Module...
£202.34
£202.34
Add to wishlist
Delivery
Standard 1-3 working days
Marketing description is not available.
Fujitsu - DDR3L - 8 GB - DIMM 240-pin
RAM memory
8 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3L-12800)
Dual rank, Low Voltage, unbuffered
Voltage
1.35 V
Fujitsu S26361-F5312-L518
PRIMERGY RX1330 M1, TX1310 M1, TX1320 M1, TX1330 M1
8 GB
Upgrade Type
System specific
DRAM
DDR3L SDRAM
DIMM 240-pin
Speed
ECC
Chips Organization
X8
Voltage
1.35 V
Fujitsu PRIMERGY RX1330 M1, TX1310 M1, TX1320 M1, TX1330 M1
Scroll to top
