BT.com
Wishlist
Fujitsu 27" P27T-7 2560x1440 5ms D-SUB DVI DisplayPort HDMI IPS LED Monitor
Delivery
Standard Due date unavailable
Enjoy perfect picture quality with 3.7 Mio pixels, outstanding ergonomics and usability as well as comfortable energy saving solutions of this 27-inch widescreen Fujitsu P Line display.
Fujitsu P27T-7 LED - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
45 kWh
Power Consumption (On mode)
30 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Marble grey
64.4 cm x 22.7 cm x 40.5 cm
9.5 kg
United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS, VCCI, C-Tick, GOST, cUL, EN 60950, SASO, TUV S, VESA FPMPMI, CCC, DDC/CI, RoHS, ISO 9241-307, WEEE, KC, Directive 2004/108/EEC, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class A
45 kWh
30 W
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
27 - 100 kHz
Video Bandwidth
360 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 6500K, 7500K
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, saturation, colour temperature, phase, clock, black level
OSD Languages
Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
HDCP, Auto Brightness Control, ECO button, DisplayView, DICOM calibrated
Marble grey
64.4 cm x 22.7 cm x 40.5 cm - with stand
9.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DisplayPort , HDMI , DVI-D (dual link) , VGA , 4 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B) , Audio line-in
Mechanical
Tilt Angle
-5/+35
Swivel Angle
340
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 0-Watt technology
1 x DisplayPort cable - 1.8 m , 1 x DVI cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x USB cable - USB Type A to B - 1.8 m
MTBF
70,000 hour(s)
United Kingdom
Power Supply
Internal
31 Watt
Power Consumption Stand by
0.3 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 64.4 cm - depth: 22.7 cm - height: 40.5 cm - weight: 9.5 kg , Without stand - width: 64.4 cm - depth: 7.2 cm - height: 38.3 cm - weight: 6.5 kg
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
35 °C
Scroll to top
