BT.com
Wishlist
Fujifilm FinePix S4500 - Digital camera - 14.0 Mpix - 30x optical zoom
Delivery
Standard Due date unavailable
Great for people that want the features and flexibility of a DSLR outfit but without the weight and hassle.
Long 30x optical zoom
The combination of versatile & functional Fujinon lens and a bright viewfinder gives a sensational shooting experience.
Fujinon 30x Optical Zoom & Wide 24mm Zoom Lens
The widely renown Fujinon Lenses are used popularly in numerous situations including satellites in outer space, TV/film, surveillance and compact cameras. With the highly adept manufacture of Fujifilm, high precision optics and technology combined allow for the best 24mm wide angle and 30x optical zoom lenses.
Super EBC - Aiming for high quality images
The lens elements used in the FinePix S4500 have been treated with multilayer Super EBC (Electron Beam Coating), the same process used for Fujinon broadcasting video lenses and large-format camera lenses acclaimed by professionals. Reducing ghosting and lens flare, the treatment promises clear image quality.
42-step Electronic Powered Zoom
The powered 30x zoom features smooth 42-step zoom control, giving you the ability to frame every shot with precise accuracy
2cm Super Macro
At a distance of just 2cm, macro photography using the FinePix S4500 allows you to capture all the exquisite detail of your subject from really close up.
High Sensitivity + CCD Shift Image Stabilisation
Dual Image Stabilisation is the combination of high sensitivity and CCD shift image stabilisation that works to eliminate blurred photos by freezing action and minimizing blurs at maximum zoom range.
Electronic Viewfinder
The FinePix S4500 offers the flexibility of framing your shots through the crisp, clear electronic viewfinder. In addition to enhanced visibility in bright daylight, the bright EVF accommodates a traditional shooting style, making it easy to steady the camera, even when shooting with the 30x zoom fully extended.
3.0-inch Large LCD
The 3.0-inch large, bright LCD display makes it easy to compose great photos. Sharing pictures is a pleasure, thanks to a high-impact 230,000-dot resolution.
6 Scene SR AUTO (Scene Recognition Auto)
Framed scenes are automatically detected and the appropriate camera settings are applied: Portrait, Landscape, Night, Macro, Night Portrait, and Backlit Portrait
Face Detection
Face Detection optimises people pictures by detecting faces, adjusting focus and the exposure to ensure bright, clear results
Red-eye Removal in detected faces
Red-eye removal automatically detects and corrects flash reflection for a perfect end result
Instantly detect up to 10 Faces!
The Face Detection can simultaneously recognise up to 10 faces in a photo. Share your group portraits using the Zoom Up function in playback, checking each detected face. Each priceless expression can be cropped and saved in to a clear high resolution photograph
Motion Panorama
Lets you take panorama photos as simply as 1, 2, 3! The camera automatically stitches together three consecutive shots, with a simple in-frame guidance to ensure the images are aligned. The resulting image is saved to the memory card as an impressive panoramic photograph.
Natural Light and with Flash
Can't decide whether it's best to use flash? Choose this mode, press the shutter and automatically capture the same scene twice: one with high sensitivity and natural light, and the second with Intelligent Flash. Later choose one or keep them both
Tracking Auto Focus
Keeps fast moving subjects in the frame and in focus, even when the zoom is fully extended. Great for capturing dynamic close-ups.
Fujifilm FinePix S4500 - digital camera - Fujinon
Digital camera - 720p - compact
Lens Included
Fujinon
Memory Card Slot
SD card
Sensor Resolution
14.0 Megapixel
Max Video Resolution
1280 x 720
Lens System
Zoom lens - 30x zoom - 4.3 - 129 mm - f/3.1-5.9
Focus Adjustment
Automatic, manual
Min Focus Distance
40 cm
Digital Zoom
6.7x
Image Stabiliser
Optical (image sensor shift mechanism)
Camera Flash
Pop-up flash
Viewfinder
Built-in - 0.2" - colour - electronic
Display
LCD display - 3"
Supported Battery
4 x AA alkaline battery (included) , 4 x AA NiMH rechargeable battery (optional) , 4 x AA lithium battery (optional)
USB 2.0
11.8 cm x 10 cm x 8.1 cm
448 g
Lens Included
Fujinon
Sensor Resolution
14.0 Megapixel
Optical Sensor Type
CCD
Effective Sensor Resolution
14,000,000 pixels
Optical Sensor Size
1/2.3"
ISO (Max)
6400
Optical Zoom
30x
Digital Zoom
6.7x
Image Stabiliser
Face Detection
Print Standard
Direct print, Exif Print support, PictBridge support
Auto Focus
TTL contrast detection
AE/AF Control
Face-priority AF, Subject-tracking AF
Face Detection
Blink Detection technology, Face Recognition, Smile Capture
Digital Video Format
AVI, MJPEG
Image Recording Format
JPEG
1280 x 720
USB 2.0
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 64, ISO 1600, ISO auto, ISO 3200 (3MP), ISO 6400 (3MP)
Exposure Metering
Multi-segment, spot, average
Exposure Metering Zones
256
Exposure Modes
Programme, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, portrait mode, night mode, text, party/indoor, fireworks, flower, sports mode, sunset, beach, night (tripod), natural light, snow, baby, natural light & with flash, smile shot, motion panorama, zoom bracketing
Bracketing Modes
Zoom Bracketing mode
White Balance
Custom, automatic, presets
White Balance Presets
Fine, incandescent, shade, fluorescent light (cool white), fluorescent light (daylight), fluorescent light (warm white)
Max Shutter Speed
1/2000 sec
Min Shutter Speed
8 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Auto Exposure Bracketing
3 steps in 1/3, 2/3 or 1 EV steps
Lens System
Fujinon zoom lens - 30x zoom - 4.3 - 129 mm - f/3.1-5.9
Focal Length Equivalent to 35mm Camera
24 - 720mm
Focus Adjustment
Automatic, manual
Min Focus Distance
40 cm
Macro Focus Range
2-100cm
Zoom Adjustment
Motorised drive
Lens Construction
11 groups / 15 elements
Camera Flash
Camera Flash
Pop-up flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
AF illuminator
Effective Flash Range
0.4 cm - 7 m
Additional Features
Continuous Shooting Speed
1.2 frames per second, 8 frames per second for 20 frames (3MP), 3.3 frames per second for 10 frames (7MP)
Self-Timer Delay
10 sec, 2sec
Additional Features
Audio recording, RGB primary colour filter, date/time stamp, digital image rotation, histogram display, in-camera red-eye removal, cropping an image, resizing an image, Smile Detection Auto Shutter, Automatic Scene Recognition (SR Auto), instant zoom, face detection, Blink Detection technology, Face Recognition, Motion Panorama
Viewfinder
Viewfinder Type
Built-in - electronic
Viewfinder Colour Support
Viewfinder Diagonal Size
0.2"
Viewfinder Resolution
200,000 pixels
Optical Viewfinder Field Coverage
97%
Display
3" LCD display
Resolution
230,000 pixels
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 , Composite video/audio output , HDMI output
Software
Software
Drivers & Utilities
Lens cap, shoulder strap, lens cap strap, video / audio / USB cable
Battery Type
AA
Details
Battery Life Details
Photo shooting - 300 shots (alkaline batteries) , Photo shooting - 500 shots (NiMH batteries) , Photo shooting - 700 shots (lithium batteries)
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
JPEG 4288 x 3216 , JPEG 4288 x 2864 , JPEG 4288 x 2416 , JPEG 3072 x 2304 , JPEG 3072 x 2048 , JPEG 3072 x 1728 , JPEG 2048 x 1536 , JPEG 2048 x 1360 , JPEG 1920 x 1080
Video Capture
AVI - 1280 x 720 - 30 fps , AVI - 640 x 480 - 30 fps , AVI - 320 x 240 - 30 fps
11.8 cm
10 cm
8.1 cm
448 g
10 - 80% (non-condensing)
Scroll to top
