BT.com
Wishlist
Fuji FinePix F770EXR Digital Camera - Blue
Delivery
Standard Due date unavailable
Long telephoto shots usually suffer from camera shake and subject movement which can ruin photos by producing blurred results. The FinePix F770EXR's highly effective CMOS-shift and high ISO image stabilization ensures that your shots stay extra-crisp and clear, even at the full 20x zoom. Turn the power on from a cold start and FinePix F770EXR is ready to shoot in only 1.5 second.
Sometimes things happen too fast for you to see them properly with your own eyes. The FinePix F770EXR can freeze the action at up to an amazing 320 fps! So you can see every single minute detail and watch things happening step by step in slow motion. The FinePix F770EXR delivers a powerful array of functions and features in a slim dynamic design. The sleek form molds to your hand with all buttons and controls just where your fingers expect them to be. When bright sunlight makes composing or viewing the monitor difficult, you can use the Fn button to easily switch to the "monitor sunlight mode" and enjoy comfortable framing and review of shots on the large 3-inch high-contrast 460,000-dot LCD.
By precisely focusing light at the same point on the focal plane, aspheric lens design eliminates the need for additional corrective lens elements. While this lens reduces distortion at wide angles, improves resolution in both center and edge areas, cuts glare and reflections, and minimizes chromatic aberration throughout the zoom range, the lens also makes possible a lighter and more compact design.
Fujifilm FinePix F770EXR - digital camera - Fujinon
Digital camera - 1080p - compact
Lens Included
Fujinon
Memory Card Slot
SD card
Image Processor
EXR Processor
Internal Storage
30 MB
Sensor Resolution
16.0 Megapixel
Lens System
20 x zoom lens - 4.6 - 92 mm - f/3.5-5.3
Focus Adjustment
Automatic
Min Focus Distance
45 cm
Digital Zoom
3.4 x
Image Stabiliser
Optical (image sensor shift mechanism)
Camera Flash
Pop-up flash
Display
LCD display - 3"
Supported Battery
1 x Li-ion rechargeable battery ( included )
Interfaces Provided
Composite video/audio, HDMI, USB 2.0
Blue
10.5 cm x 3.6 cm x 6.3 cm
213 g
Lens Included
Fujinon
Enclosure Colour
Blue
Sensor Resolution
16.0 Megapixel
Optical Sensor Type
BSI EXR CMOS
Effective Sensor Resolution
16,000,000 pixels
Optical Sensor Size
1/2"
ISO (Max)
12800
Optical Zoom
20 x
Digital Zoom
3.4 x
Image Processor
EXR Processor
Image Stabiliser
Face Detection
Navigation
GPS receiver
Services and Applications
YouTube capture mode
Print Standard
Direct print, Exif Print support, PictBridge support, PRINT Image Matching
Auto Focus
TTL contrast detection
AE/AF Control
Face-priority AF, Subject-tracking AF
Face Detection
Face Recognition, face-priority AF function, Pet Detection
Digital Video Format
H.264
Image Recording Format
JPEG, RAW, RAW + JPEG, MPO
Interfaces Provided
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO 3200, ISO auto, ISO 6400 (8MP), ISO 12800 (4MP)
Exposure Metering
Multi-segment, spot, average
Exposure Metering Zones
256
Exposure Modes
Programme, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, portrait mode, night mode, text, party/indoor, fireworks, flower, Underwater, sports mode, sunset, beach, night (tripod), natural light, snow, natural light & with flash, portrait enhancer, dog, cat
Bracketing Modes
Dynamic Range Bracketing, Film Simulation Bracketing
Special Effects
Black & White, Sepia, Film Simulation, Image Overlay
White Balance
Custom, automatic, presets
White Balance Presets
Fine, incandescent, shade, fluorescent light (cool white), fluorescent light (daylight), fluorescent light (warm white), Underwater
Max Shutter Speed
1/2000 sec
Min Shutter Speed
8 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Auto Exposure Bracketing
3 steps
Lens System
Fujinon 20 x zoom lens - 4.6 - 92 mm - f/3.5-5.3
Focal Length Equivalent to 35mm Camera
25 - 500mm
Focus Adjustment
Automatic
Min Focus Distance
45 cm
Macro Focus Range
5-300cm
Zoom Adjustment
Motorised drive
Lens Construction
11 groups / 14 elements
Built-in lens shield, ED glass, aspherical lens
Camera Flash
Camera Flash
Pop-up flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
AF illuminator
Effective Flash Range
0.15 m - 3.7 m : ISO auto ( wide lens ) , 0.9 m - 2.4 m : ISO auto ( tele lens )
Additional Features
Continuous Shooting Speed
8 frames per second, 3 frames per second, 5 frames per second, 11 frames per second for 16 frames (8MP)
Self Timer Delay
10 sec, 2sec
Additional Features
Audio recording, RGB primary colour filter, date/time stamp, digital image rotation, histogram display, in-camera red-eye removal, cropping an image, resizing an image, Scene Detection Technology, takes photos while film recording, face detection, Motion Detection Technology, Motion Panorama 360, high-speed recording, EXR AUTO mode
Display
3" LCD display
Resolution
460,000 pixels
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Stereo
Connector Type
1 x USB 2.0 , 1 x composite video/audio output , 1 x HDMI output
Software
Software
Drivers & Utilities, MyFinePix Studio
Battery charger, hand strap, USB cable, audio / video cable
Battery Type
Fujifilm NP-50A
Details
Battery Life Details
Photo shooting - 300 shots ( AUTO mode )
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDXC UHS-I Memory Card
Internal Storage
30 MB
Image Storage
JPEG 4608 x 3456 , JPEG 4608 x 3072 , JPEG 4608 x 2592 , JPEG 3264 x 2448 , JPEG 3264 x 2176 , JPEG 3264 x 1840 , JPEG 2304 x 1728 , JPEG 2304 x 1536 , JPEG 1920 x 1080
Video Capture
H.264 - 1920 x 1080 - 30 fps , H.264 - 1280 x 720 - 30 fps , H.264 - 640 x 480 - 30 fps , H.264 - 640 x 480 - 80 fps , H.264 - 320 x 240 - 160 fps , H.264 - 320 x 112 - 320 fps
10.5 cm
3.6 cm
6.3 cm
213 g
10 - 80% (non-condensing)
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Almost a Pocket Sized DSLR - almost
Reviewed by Lady Brighid on 05/05/2012
I have a wardrobe of cameras. This is my birthday present - and even though birthday isn't until July - this is a nice looking piece of kit. It will take some playing with. I am impressed at the amount of selection for the menu there is. I have been mostly a Panasonic camera user; and before that a Minolta user. My partner is on his 2nd Fuji; and his recent model is really advanced. After trying his newer model; and then seeing this - I thought; if it is anything like the bigger, top model - then this will be good. Nope; it isn't good; it is pretty darn good. I am impressed at what they have packed in to a nice neat small package. It is light; and all the controls are within easy reach. I think if you give it a go - you will find you are very happy with it! Happy shooting!
Scroll to top
