BT.com
Wishlist
Freecom ToughDrive 2.5" 2TB USB 3.0
Freecom ToughDrive 2.5" 2TB USB...
£122.76
£122.76
Add to wishlist
Delivery
Standard 1-3 working days
Your data requires the best possible protection, especially during mobile use. The Freecom Tough Drive 3.0 is a password protected mobile hard drive with a conveniently integrated USB 3.0 cable. Thanks to the internal suspension and shock-absorbing silicone enclosure, this mobile hard drive is resistant to sudden impact and shocks. The Tough Drive 3.0 is also available as high specified 7200 RPM drive (30% faster).
Freecom ToughDrive - hard drive - 2 TB - USB 3.0
Hard drive - external (portable)
2 TB
2.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Spindle Speed
5400 rpm
Shock resistant, water resistant, password authentication, dust-proof, silicone outer shell, fanless design
Power Source
USB bus
Enclosure Colour
Dark grey
14 cm x 8.3 cm x 1.9 cm
200 g
2 years warranty
2 TB
2.5"
USB 3.0
Internal Drive Interface
Serial ATA
14 cm
8.3 cm
1.9 cm
200 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Spindle Speed
5400 rpm
Reliability
MTBF
50,000 hours
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type A
Compatible Bay
2.5"
Power Source
USB bus
Software Included
Drivers & Utilities, NERO BackItUp
Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8
System Requirements Details
Windows XP/7/8 - Pentium III - 900 MHz - RAM 256 MB , Windows Vista - Pentium III - 900 MHz - RAM 512 MB , MacOS X 10.6 or later - RAM 256 MB
1 x USB 3.0 cable - integrated
FCC, IP54
Enclosure Colour
Dark grey
10 °C
35 °C
Other bundles
£122.76
Half Price Hard Drive Case with portable hard drives
Save £4.99
£127.75
Scroll to top
