BT.com
Wishlist
Freecom Mobile Drive Sq TV 500GB Slim USB 3.0 2.5" Portable Drive
Freecom Mobile Drive Sq TV 500GB...
£65.35
£65.35
Add to wishlist
Delivery
Standard Due date unavailable
USB recording - record TV programmers directly from your TV to an external hard drive, connected to a USB port on your TV. More and more TVs have this feature enabled. Why not make full use of it? And when you do, why not use a uniquely designed external hard drive which looks stunning next to your TV The Mobile Drive Sq TV has it all. Looks and performance. For your convenience it also comes with a cradle with which you can fix the Mobile Drive Sq to the back of your TV, should you want to keep it out of sight.
Designed by acclaimed industrial designer Arman Emami from Germany, the Mobile Drive Sq TV features a unique organic design, like nothing you've ever seen before. Smooth lines and a square form factor. To make it less susceptible to scratches and fingerprints, the Mobile Drive Sq TV's enclosure cover is made from sandblasted stainless steel. In short - the Sq is guaranteed to turn some heads! The drive can of course also be used as a standard external hard drive. The Mobile Drive Sq TV boasts the USB 3.0 interface, ensuring ultra fast transfer speeds compared to standard USB 2.0. The drive is fully downwards compatible with older USB 2.0 ports, so you can use it on any computer and be ready for the future at the same time! The Mobile Drive Sq TV is powered by the USB port, no need for additional long cables or power adapters. If you're looking for an exclusive looking hard drive with matching performance and ultimate portability features, look no further - the Mobile Drive Sq TV is the drive to have!
Freecom Mobile Drive Sq TV - hard drive - 500 GB - USB 3.0
Hard drive - external (portable)
500 GB
2.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / internal: 5000 MBps
Power Source
USB bus
Enclosure Colour
Black, silver
12 cm x 12 cm x 1.05 cm
195 g
500 GB
2.5"
USB 3.0
12 cm
12 cm
1.05 cm
195 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Drive Transfer Rate
5000 MBps (external)
Expansion & Connectivity
1 x USB 3.0
Compatible Bay
2.5"
Power Source
USB bus
1 x USB cable - external
Enclosure Colour
Black, silver
Other bundles
Freecom Mobile Drive Sq TV 500GB Slim USB 3.0 2.5"...
£65.35
Half Price Hard Drive Case with portable hard drives
Save £4.99
£70.34
Scroll to top
