BT.com
Wishlist
Freecom Hard Drive Dock Quattro For 2.5 / 3.5" SATA HDDs
Freecom Hard Drive Dock Quattro For...
£54.85
15 in stock
£54.85
Add to wishlist
Delivery
Standard 3-5 working days
The Freecom Hard Drive Dock Quattro provides even more flexibility. Connect any 2.5" and 3.5" SATA hard drive in the dock and connect it to your PC or Mac via USB 2.0, FireWire 800, FireWire 400 or eSATA. It is ideal for temporary use of your internal hard drive, just in case you need to retrieve some files quickly.
Freecom Hard Drive Dock Quattro - HDD docking station - SATA 3Gb/s - eSATA, FireWire 800, USB 2.0
HDD docking station - external
Bays
1
Bus Type
Expansion Bays
1 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility
2.5", 3.5"
SATA 3Gb/s
Data Transfer Rate
300 MBps
Supported Devices
Hard drive
Bays
1
2.5", 3.5"
Host Bus
Storage Controller
SATA 3Gb/s
Data Transfer Rate
300 MBps
Supported Devices
Hard drive
Bays
1 x SATA 3Gb/s - 7 pin Serial ATA
1 x USB 2.0 - 4 pin USB Type A , 1 storage - eSATA-300 - 7 pin external Serial ATA , 1 x FireWire - 6 PIN FireWire , 1 x FireWire 800 - 9 pin FireWire 800
Other bundles
Freecom Hard Drive Dock Quattro For 2.5 / 3.5" SATA...
£54.85
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.60
£58.45
Scroll to top
