BT.com
Wishlist
Freecom 1TB Mobile Drive XXS 3.0 USB 3.0 2.5" Portable Hard Drive
Freecom 1TB Mobile Drive XXS 3.0...
£70.14
£70.14
Add to wishlist
Delivery
Standard Due date unavailable
Looking for the high possible capacity in the smallest possible size? Meet the smallest mobile drive in the world! The Mobile Drive XXS is the perfect solution for you.
Freecom's Mobile Drive XXS is the ideal mobile hard drive if you travel frequently. Or when you just need to have your files nearby at all times. Store them on your XXS and always have your business and personal files with you.
The Mobile Drive XXS is made out of rubber which not only provides a stylish look, but also gives the necessary grip to avoid dropping your hard drive.
Freecom Mobile Drive XXS 3.0 - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
2.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Power Source
USB bus
Enclosure Colour
2 years warranty
1 TB
2.5"
USB 3.0
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Compatible Bay
2.5"
Power Source
USB bus
1 x USB cable - external
Enclosure Colour
Scroll to top
