BT.com
Wishlist
Fractal Design Venturi HF-14 (140mm) Computer Cooling Fan
Fractal Design Venturi HF-14...
£14.76
£14.76
Add to wishlist
Delivery
Standard Due date unavailable
Designed with a variety of performance-increasing and noise-reducing features, this fan can move an amazing amount of air compared to other fans at the same, minimal noise level.
The HF-14 comes with two sets of solid vibration-dampening rubber corners: one for standard 140mm fan hole spacing (125mm) and one compatible with the standard 120mm hole spacing (105mm). The Venturi High Flow Series fans are ideal for those looking for a perfect balance between high performance and low noise built from sturdy, high quality materials.
Fractal Design Venturi Series case fan
Case fan
Package Content
4 screws, 4 corners
Fan Diameter
140 mm
Fan Height
25 mm
Air Flow
78.5 cfm
Noise Level
18.3 dBA
Power Connector
3-pin plug
202 g
Case fan
Package Content
4 screws, 4 corners
202 g
Heatsink & Fan
Fan Diameter
140 mm
Fan Height
25 mm
Air Flow
78.5 cfm
Noise Level
18.3 dBA
Power Connector
3-pin plug
Cable Length
50 cm
MTBF
150,000 hour(s)
Fractal Design Venturi HF-14 (140mm) Computer Cooling...
£14.76
Save on this ideal PC Build kit!
Save £8.40
£33.98
Scroll to top
