BT.com
Wishlist
Fractal Design Venturi HF-12 (120mm) Computer Cooling Fan
Delivery
Standard Due date unavailable
The Venturi High Flow series fans are optimized for low-restriction airflow environments, making them an excellent choice for computer case fans, or other low-restriction usage scenarios. Designed with a variety of performance-increasing and noise-reducing features, these fans can move an amazing amount of air compared to other fans at the same, minimal noise level. The Venturi High Flow series fans are ideal for those looking for a perfect balance between high performance and low noise built from sturdy, high quality materials.
Fractal Design Venturi Series case fan
Case fan
Package Content
4 screws
Fan Diameter
120 mm
Case fan
Package Content
4 screws
Heatsink & Fan
Fan Diameter
120 mm
Scroll to top
