BT.com
Wishlist
Fractal Design Silent Series R3 (92mm) Case Fan
Fractal Design Silent Series R3...
£6.94
38 in stock
£6.94
Add to wishlist
Delivery
Standard 3-5 working days
Fractal Design Silent Series R3 fans offer excellent value for money, with good performance and assured reliability. All Fractal Design Silent Series R3 fans are equipped with long-life rifle bearings and an easy-to-hide, sleek black cable. The Silent Series R3 delivers suitable options for replacing loud or damaged fans in both computers and many other electronic devices.
Fractal Design Silent Series R3 - case fan
Case fan
Package Content
4 screws
Black, white
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
1500 rpm
Air Flow
24.4 cfm
Noise Level
18.3 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
9.2 cm x 9.2 cm x 2.5 cm
80 g
Case fan
Package Content
4 screws
9.2 cm
9.2 cm
2.5 cm
80 g
Black, white
Heatsink & Fan
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
1500 rpm
Air Flow
24.4 cfm
Air Pressure
0.79 mm
Noise Level
18.3 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
Start Voltage
6 V
Rated Current
0.07 A
Power Consumption
0.6 W
Cable Length
35 cm
MTBF
40,000 hour(s)
Scroll to top
