BT.com
Wishlist
Fractal Design Silent Series R3 (120mm) Case Fan
Fractal Design Silent Series R3...
£7.78
£7.78
Add to wishlist
Delivery
Standard Due date unavailable
Fractal Design Silent Series R3 fans offer excellent value for money, with good performance and assured reliability. All Fractal Design Silent Series R3 fans are equipped with long-life rifle bearings and an easy-to-hide, sleek black cable. The Silent Series R3 delivers suitable options for replacing loud or damaged fans in both computers and many other electronic devices.
Fractal Design Silent Series R3 - case fan
Case fan
Package Content
4 screws
Black, white
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
1200 rpm
Air Flow
46.5 cfm
Noise Level
20.5 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
12 cm x 12 cm x 2.5 cm
125 g
Case fan
Package Content
4 screws
12 cm
12 cm
2.5 cm
125 g
Black, white
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
1200 rpm
Air Flow
46.5 cfm
Air Pressure
0.78 mm
Noise Level
20.5 dBA
Power Connector
3-pin plug
Rated Voltage
12 V
Start Voltage
6 V
Rated Current
0.12 A
Power Consumption
1 W
Cable Length
35 cm
MTBF
40,000 hour(s)
£7.78
Save on this ideal PC Build kit!
Save £8.29
£26.95
Scroll to top
