BT.com
Wishlist
Fractal Design Silent Series R2 60mm Case Fan
Delivery
Standard Due date unavailable
These fans have been specifically developed to deliver significant airflow while maintaining low noise levels. All Silent series R2 fans are equipped with high performance hydraulic bearings, increasing both fan performance and reliability. The cable on each Silent series R2 fan is fully sleeved for effortless cable routing and enhanced aesthetics.
Fractal Design Silent Series R2 60mm - case fan
Case fan
Package Content
4 screws, 4 rubber screws
Fan Diameter
60 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
3000 rpm
Air Flow
20 cfm
Noise Level
17 dB
Power Connector
3-pin plug
6 cm x 6 cm x 2.5 cm
56.1 g
Package Type
Retail
Case fan
Package Content
6 cm
6 cm
2.5 cm
56.1 g
Heatsink & Fan
Fan Diameter
60 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
3000 rpm
Air Flow
20 cfm
Air Pressure
2.89 mm
Noise Level
17 dB
Power Connector
3-pin plug
Start Voltage
6 V
Package Type
Retail
Scroll to top
