Click to visit BT.com
BT.com
Wishlist
Fractal Design Silent Series R2 120mm Case Fan
Quicklinx: 8K13WS00
Mfr#: FD-FAN-SSR2-120
The fan has been specifically developed to deliver significant airflow while maintaining low noise levels.
This silent series R2 fan is equipped with high performance hydraulic bearings, increasing both fan performance and reliability. Using the rubber screws allows mechanical decoupling from the case itself, reducing vibrations and decreasing the noise level.
The cable on silent series R2 fan is fully sleeved for effortless cable routing and enhanced aesthetics.
Fractal Design Silent Series R2 120mm - case fan
Case fan
Package Content
Screws, cable, 4 rubber screws
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
1200 rpm
Air Flow
40.6 cfm
Noise Level
15 dB
12 cm x 12 cm x 2.5 cm
113.3 g
Package Type
Retail
Case fan
Package Content
12 cm
12 cm
2.5 cm
113.3 g
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Hydraulic bearing
Rotation Speed
1200 rpm
Air Flow
40.6 cfm
Air Pressure
1.07 mm
Noise Level
15 dB
Start Voltage
11 V
Cable Length
50 cm
Mounting Kit
Included
Package Type
Retail
