BT.com
Wishlist
Fractal Design Kelvin S24 Water Cooling System Black
Fractal Design Kelvin S24 Water...
£91.70
£91.70
Add to wishlist
Delivery
Standard Due date unavailable
Simple to install, silent operation, powerful performance and easy expandability define the Kelvin series. The silent high-performance ceramic pump is strong enough to support considerable expansion, should you decide to include GPU blocks and/or additional radiators in the same loop.
The Kelvin series water cooling systems are constructed from enthusiast class components. Both the CPU block and the radiator are made from pure copper, for maximum performance and an increased product life span with zero maintenance required.
All modern CPU sockets are supported by the versatile, easy-to-use mounting kit.
Fractal Design Kelvin S24 - liquid cooling system
Liquid cooling system
Package Content
Thermal paste, mounting hardware, PWM splitter cable
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+
Heatsink Material
Copper
Fans Qty
Dual
Fan Diameter
120 mm
Rotation Speed
800-1700 rpm
Air Flow
62.4 cfm
Noise Level
26.9 dBA
Rated Voltage
12 V
Pulse-width modulation (PWM) support
2 kg
G1/4" thread
Package Content
2 kg
Heatsink & Fan
Compatible With
Heatsink Material
Copper
Heatsink Dimensions
69 mm x 69 mm x 40 mm
Fans Qty
2
Fan Diameter
120 mm
Rotation Speed
800-1700 rpm
Air Flow
62.4 cfm
Air Pressure
2.33 mm
Noise Level
26.9 dBA
Rated Voltage
12 V
Rated Current
0.18 A
G1/4" thread
£91.70
Save on this ideal PC Build kit!
Save £8.40
£110.92
Scroll to top
