BT.com
Wishlist
Fractal Design Intergra (450W) Internal Power Supply Unit
Fractal Design Intergra (450W)...
£52.95
£52.95
Add to wishlist
Delivery
Standard Due date unavailable
Fractal Design Integra M Series power supply units feature excellent electrical performance, including 80PLUS Bronze certified efficiency. The modular flat cable system allows for a clean installation, and enhances airflow patterns inside the case. The short length makes for easy installation in small computer cases, and the extra-long cable accommodates modern, bottom-PSU cases. Fractal Design Integra M units are equipped with a large temperature-controlled fan for reduced noise levels and optimum cooling. The Integra M is a great choice for medium-performance gaming computers and workstations.
Fractal Design Integra M - power supply - 450 Watt
Power supply - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification
80 PLUS Bronze
1.435 kg
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
450 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 1 x 8 pin PCI Express power with detachable 2 pin section , 1 x 15 pin Serial ATA power , 1 x 4 PIN internal power
Cooling System
120 mm fan
Cable ties, thumbscrews
15 cm x 14 cm x 8.6 cm
3 years warranty
United Kingdom
Input Voltage
AC 100-240 V
Frequency Required
50/60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
450 Watt
Output Current
+3.3V - 20 A , +5V - 15 A , +12V1 - 37 A , -12V - 0.5 A , +5VSB - 2.5 A
80 PLUS Bronze
Power cable
MTBF
100,000 hours
Cooling System
120 mm fan
Over voltage protection, overpower protection, undervoltage protection, short-circuit protection, temperature controlled fan, Intel 4th-gen CPU (Haswell) compatible
TUV, PCT, FCC, RoHS, WEEE, cULus, ErP 2013
Limited warranty - 3 years
15 cm
14 cm
8.6 cm
1.435 kg
Shipping Width
28.5 cm
Shipping Depth
20.2 cm
Shipping Height
11.5 cm
Shipping Weight
1.63 kg
Scroll to top
