BT.com
Wishlist
Fractal Design EDISON M Series (650W) Power Supply Unit
Fractal Design EDISON M Series...
£112.00
Hurry, only 3 left in stock!
£112.00
Add to wishlist
Delivery
Standard 1-3 working days
The Fractal Design Edison M series of power supplies feature excellent electrical performance, including 80PLUS Gold certified efficiency.
Designed for maximum reliability, the Edison M units feature Japanese electrolytic capacitors with a full protection suite, including over-temperature protection. The modular cable system assists with a clean installation and the extra-long ATX 12 V cable accommodates cases with bottom mounted PSU positions.
Fractal Design Edison M units are equipped with a large, temperature-controlled FDB-bearing 120 mm fan contributing to a maximum lifespan while keeping noise levels at a minimum.
The Edison M is a highly reliable choice, for both gaming computers and powerful workstations.
Fractal Design Edison M 650W - power supply - 650 Watt
Power supply - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification
80 PLUS Gold
2.4 kg
United Kingdom
Power Capacity
650 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 6 x 8 pin PCI Express power with detachable 2 pin section , 8 x 15 pin Serial ATA power , 5 x 4 PIN internal power
Cooling System
120 mm fan
Cable ties
15 cm x 16 cm x 8.6 cm
5 years warranty
United Kingdom
Power Capacity
650 Watt
Output Current
+3.3V - 20 A , +5V - 20 A , +12V1 - 54 A , -12V - 0.3 A , +5VSB - 2.5 A
80 PLUS Gold
Cable ties
MTBF
100,000 hours
Cooling System
120 mm fan
Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, DC-DC technology, Intel 4th-gen CPU (Haswell) compatible, fluid dynamic bearing cooling fan
ErP 2013
Limited warranty - 5 years
15 cm
16 cm
8.6 cm
2.4 kg
Shipping Width
29.9 cm
Shipping Depth
12.2 cm
Shipping Height
18.5 cm
Shipping Weight
3 kg
Scroll to top
