BT.com
Wishlist
Fractal Design Define XL R2 Black
£120.48
£120.48
Add to wishlist
Delivery
Standard Due date unavailable
Fractal Design builds on the success of its awarding-winning Define XL computer case with the Define XL R2. This updated chassis carries on the family tradition of providing superb cooling and ventilation capabilities with exceptional expandability, in a sleek and stylish Scandinavian form.
The Define XL R2, which includes Fractal Design's innovative ModuVent feature, has an updated internal layout that offers greater expandability, modularity and flexibility, including capacity for 9 PCI cards and two HDD cages that can be repositioned to provide more space for water cooling radiators.
Fractal Design Define XL R2 - tower - extended ATX
System cabinet
Tower
Black Pearl
I/O Connectors
2 x USB 2.0 , 2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX, Extended ATX, XL-ATX
System Cabinet Features
Air filter, front panel door, fan speed controller, blue LED, removable HDD rack, water cooling holes, ModuVent, bottom mounted PSU holder, cable management system
No power supply
23.2 cm x 56 cm x 55.9 cm
16.4 kg
Tower
Max Mainboard Size
Extended ATX
Internal Bays Qty
8
Front Accessible Bays Qty
4
Black Pearl
Cooling System
Front: 140 mm fan x 1 / intake / 1000 rpm / hydraulic bearing , Front: 120/140 mm fan mount x 1 / intake , Bottom: 140 mm fan x 1 / intake / 1000 rpm / hydraulic bearing , Top: 120/140 mm fan mount x 2 / intake , Rear: 140 mm fan x 1 / intake / 1000 rpm / hydraulic bearing , Side: 140 mm fan mount x 1 / intake
Expansion Bays
8 (total) / 8 (free) x internal - 3.5" , 4 (total) / 4 (free) x front accessible - 5.25"
Expansion Slots
9 x Expansion Slot
2 x USB 2.0 , 2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
Accessory box
No power supply
23.2 cm
56 cm
55.9 cm
16.4 kg
£120.48
Save on this ideal PC Build kit!
Save £16.94
£145.86
Scroll to top
