BT.com
Wishlist
Fractal Design Define S Computer Chassis
Fractal Design Define S Computer...
£68.76
More than 50 in stock
£68.76
Add to wishlist
Delivery
Standard 3-5 working days
The Fractal Design Define S lends the appearance, sound dampening technology, and support for a wide variety of components from the widely popular Define Series, while introducing an innovative internal layout. The Define S case is packed with intelligently designed enthusiast-oriented features delivering a silent case with powerful and expansive air and liquid cooling support, presented in a stunning Scandinavian inspired construction.
The modernized internal layout of the Define S omits the optical drive bays, instead focusing on a clear straight airflow path and uncompromising water cooling support.
The Define S case reaches the highest level of silent computing through strategically placed dense sound-absorbing material, multiple ModuVent fan vent covers and finely tuned Dynamic Series fans.
Fractal Design Define S - tower - ATX
System cabinet
Tower
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Vibration damping, front dust filter, water cooling holes, ModuVent, cable management system, bottom dust filter, toolless design
23.3 cm x 52 cm x 45.1 cm
8.5 kg
Tower
Max Mainboard Size
ATX
Internal Bays Qty
5
Cooling System
Front: 140 mm fan x 1 / 1000 rpm , Rear: 140 mm fan mount x 1 / 1000 rpm , Front: 120/140 mm fan mount x 2 , Top: 120/140 mm fan mount x 3 , Bottom: 120/140 mm fan mount x 1
CPU Cooler Max Height
180 mm
Video Card Max Length
450 mm
Expansion Bays
3 (total) / 3 (free) x internal - 2.5" / 3.5" shared , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
7
23.3 cm
52 cm
45.1 cm
8.5 kg
£68.76
Save on this ideal PC Build kit!
Save £10.63
£87.93
Scroll to top
