BT.com
Wishlist
Fractal Design Define R5 Computer Case (Titanium) with USB 3.0
Fractal Design Define R5 Computer...
£92.07
More than 50 in stock
£92.07
Add to wishlist
Delivery
Standard 1-3 working days
The Fractal Design Define R5 is the next evolution in the widely popular Define Series. Packed with intelligently designed enthusiast-oriented features delivering a silent case with powerful and expansive air and liquid cooling support, presented in a stunning Scandinavian inspired construction.
The Define R5 case reaches the highest level of silent computing through strategically placed dense sound-absorbing material, ModuVent fan vent covers and finely tuned Dynamic Series fans.
The Define R5 was designed with configurability in mind, accommodating with hard drives and all modern graphics card. Should you wish to expand your system with water cooling components or more fans the layout can easily be configured to meet your demand.
Fractal Design Define R5 - tower - ATX
System cabinet
Tower
Titanium window
I/O Connectors
2 x USB 2.0 , 2 x USB 3.0 , 1 x audio line-in , 1 x audio line-out
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Front panel door, fan speed controller, blue LED, ModuVent, cable management system, filtered fan slots
23.2 cm x 52.1 cm x 45.1 cm
11.2 kg
Tower
Max Mainboard Size
ATX
Internal Bays Qty
10
Front Accessible Bays Qty
2
Titanium window
Cooling System
Front: 140 mm fan x 1 / 1000 rpm , Rear: 140 mm fan x 1 / 1000 rpm , Top: 140 mm fan mount x 3 , Bottom: 140 mm fan mount x 2 , Side: 140 mm fan mount x 1
CPU Cooler Max Height
180 mm
Video Card Max Length
310 mm
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , 8 (total) / 8 (free) x internal - 3.5" , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
7
Accessory box
23.2 cm
52.1 cm
45.1 cm
11.2 kg
Fractal Design Define R5 Computer Case (Titanium) with...
£92.07
Save on this ideal PC Build kit!
Save £10.36
£111.62
Scroll to top
