BT.com
Wishlist
Fractal Design Define R4 Titanium Grey Mid-Tower Case
Delivery
Standard Due date unavailable
Define R4
The Fractal Design Define R4 is the latest in the Define Series of computer cases offering minimalistic and stunning Scandinavian design fused with maximum sound reduction, configurability and functionality. The Define R4 side and front door panels are fitted with dense, sound-absorbing material making it a benchmark for noise reduction. Moreover, the Define R4 accommodates up to 8 HDDs, all modern graphics card sizes, and multiple ventilation options - including two standard Silent Series R2 hydraulic bearing fans - to keep internal components at optimal temperatures.
For ultimate functionality, the Define R4 features a front interface with USB 3.0 and an integrated threespeed fan controller behind the front panel door.
  • High density noise-reducing material for an optimal silent case **To achieve a high level of noise reduction, material with mass should be incorporated which is what we strive to achieve with the dense bitumen used on the side panels
  • Patent pending ModuVent™ design allowing the user to choose between optimal silence or maximum airflow
  • Top HDD cage (5 trays total) can be rotated 90 degrees or removed for additional airflow or to accommodate long graphic cards up to 430mm in length
  • Three-speed fan controller is strategically integrated in the front panel and supports up to 3 fans
  • Two Silent Series R2 fans included, featuring hydraulic bearings contributing to a longer life expectancy - Silent Series R2 retail fans will now come standard in all cases
  • Wider case body that allows for improved cable routing behind the motherboard - now 26mm wide
  • New tool-less front fan holder makes switching front fans a breeze
  • Two SSDs can be mounted on the back of the motherboard plate
General Specifications
  • Motherboard compatibility: ATX, Micro ATX, Mini ITX
  • Front interface: 2 - USB 3.0, 2 - USB 2.0, Audio in/out, Power button with LED (blue), Reset button, Fan controller (behind door)
  • Drive bay capacity 2 - 5.25" bays / 8 - 3.5" HDD trays - all compatible with SSDs / 2 - 2.5" extra SSD positions
  • Expansion slots: 7 + 1
  • PSU compatibility: ATX PSUs up to 170 mm deep when using the bottom fan location; when not using this fan location longer PSUs (up to 270 mm deep) can be used
  • Graphics card compatibility: Graphics cards up to 295mm in length with the top HDD cage installed
  • With the top cage removed, graphics cards up to 430mm in length may be installed
  • Cooling / Ventilation: 3 - ModuVent™ plates - two in the top and one in the side / 7 - Fan positions (2 fans included) / Filtered fan slots in front and bottom
  • CPU cooler compatibility: CPU coolers up to 170 mm tall (when no fan is installed in the side panel)
  • Additional information: 26 mm of space for cable routing behind the motherboard plate / Thick rubber grommets on all holes on the motherboard plate
  • Case dimensions (WxHxD) (mm): 232 x 464 x 523
  • Net weight (kg) - 12,3
Package contents
  • Define R4 computer case
  • User manual
  • Accessory box
Cooling System
  • Front: 1 - hydraulic bearing 140mm Silent Series R2 fan, 1000 RPM speed (included) / 1 - 120/140mm fan
  • Rear: 1 - hydraulic bearing 140mm Silent Series R2 fan, 1000 RPM speed (included)
  • Top: 2 - 120/140mm fans - positions also support 240/280mm radiators
  • Bottom: 1 - 120/140mm fan
  • Side: 1 - 140mm fan
  • Fan controller: 1 - integrated fan controller for up to 3 fans (included)
Fractal Design Define R4 - tower - ATX
System cabinet
Tower
Titanium grey
I/O Connectors
2 x USB 2.0 , 2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Rotational drive cage, fan speed controller, front dust filter, floor dust filter, cable management holes, ModuVent, bottom mounted PSU holder
No power supply
Specification Compliance
ATX
23.2 cm x 46.4 cm x 52.3 cm
12.3 kg
Tower
Max Mainboard Size
ATX
ATX
Internal Bays Qty
10
Front Accessible Bays Qty
2
Titanium grey
Cooling System
Front: 140 mm fan x 1 / 1000 rpm , Front: 120/140 mm fan mount x 1 , Rear: 140 mm fan x 1 / 1000 rpm , Top: 120/140 mm fan mount x 2 , Bottom: 120/140 mm fan mount x 1 , Side: 140 mm fan mount x 1
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , 8 (total) / 8 (free) x internal - 3.5" , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
8 x Expansion Slot
2 x USB 2.0 , 2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
RoHS, WEEE
No power supply
23.2 cm
46.4 cm
52.3 cm
12.3 kg
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* Great case - but weighs a ton
Reviewed by Anonymous on 03/03/2014
Great case, plenty of room, easy to install.. however, if you ever want to move it around like I do, prepare to lift a heavy case.
Scroll to top
