BT.com
Wishlist
Fractal Design ARC Miditower R2 Side Window
Fractal Design ARC Miditower R2...
£84.73
5 in stock
£84.73
Add to wishlist
Delivery
Standard 3-5 working days
As the newest member of the Arc family of airflow cases, the Arc Midi R2 is developed with high-performance computer systems in mind. Featuring three high performance silent series R2 fans and ample water cooling options, the Arc Midi R2 layout maximizes airflow throughout the case and keeps even the most demanding systems at cool temperatures. Designed to house even the thickest radiators in both the top and front panels without extensive modifications, the Arc Midi R2 offers all this within a mid size case.
Fractal Design Arc Midi R2 - mid tower - ATX
System cabinet
Mid tower
I/O Connectors
2 x USB 3.0 , 1 x microphone , 1 x headphones
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Windowed side panel, rotational drive cage, fan speed controller, meshed front panel, removable front panel, cable management holes, meshed top
No power supply
Specification Compliance
ATX
23 cm x 51.5 cm x 46 cm
10.7 kg
Mid tower
Max Mainboard Size
ATX
ATX
Internal Bays Qty
10
Front Accessible Bays Qty
2
Cooling System
Front: 140 mm fan x 1 / 1000 rpm , Rear: 140 mm fan x 1 / 1000 rpm , Top: 140 mm fan x 1 / 1000 rpm , Front: 120/140 mm fan mount x 1 , Top: 120/140 mm fan mount x 2 , Bottom: 120/140 mm fan mount x 1
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , 8 (total) / 8 (free) x internal - 3.5" , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
8 x Expansion Slot
2 x USB 3.0 , 1 x microphone - mini-jack , 1 x headphones - mini-jack
No power supply
23 cm
51.5 cm
46 cm
10.7 kg
Scroll to top
