BT.com
Wishlist
Fortinet FortiSwitch 524D Switch
£2,008.69
£2,008.69
Add to wishlist
Delivery
Standard Due date unavailable
FortiSwitch secure access switches deliver outstanding security, performance and manageability for threat conscious small to mid-sized businesses, distributed enterprises and branch offices. This single pane of glass management provides complete visibility and control of all users and devices on the network, regardless of how they connect. When a device connects to the Ethernet port of a secure access switch, it is first identified, and then the user is authenticated. Once authenticated, access to the network is granted based on pre-defined security policy from the FortiGate, ensuring secure network access across the enterprise, without impacting the user experience.
Fortinet FortiSwitch 524D - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x 10 Gigabit SFP+ + 2 x 40 Gigabit QSFP+
Performance
Switching capacity: 288 Gbps , Throughput: 428 Mpps , Latency: 2 µs
Virtual interfaces (VLANs): 4000 , Maximum aggregation groups: 24
MAC Address Table Size
96K entries
Jumbo Frame Support
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, CLI
Routing, auto-negotiation, VLAN support, IGMP snooping, Syslog support, port mirroring, SNTP support, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Jumbo Frames support, DHCP relay, Link Aggregation Control Protocol (LACP), DHCP client, Management Information Base (MIB), static routing, tagged VLAN, Storm Control
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP)
44 cm x 31 cm x 4.4 cm
6.2 kg
Bundled Services
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
96K entries
Jumbo Frame Support
Routing Protocol
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
2 GB
Flash Memory
128 MB
24 x 1000Base-TX - RJ-45 , 4 x 10Gbit LAN - SFP+ , 2 x 40Gbit LAN - QSFP+ , 1 x 1000Base-T - RJ-45 - management , 1 x console - RJ-45
Internal power supply
75 Watt
MTBF
10 years
UL, VCCI, BSMI, CB, FCC, RoHS, RCM
44 cm
31 cm
4.4 cm
6.2 kg
Limited warranty - lifetime
45 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Scroll to top
