BT.com
Wishlist
Fortinet FortiSwitch 448D Switch
£2,678.26
£2,678.26
Add to wishlist
Delivery
Standard Due date unavailable
FortiSwitch Secure Access switches deliver outstanding security, performance and manageability for threat conscious small to mid-sized businesses, distributed enterprises and branch offices. Tightly integrated into the FortiGate Network Security Platform, the FortiSwitch Secure Access switches can be managed directly from the familiar FortiGate interface. This single pane of glass management provides complete visibility and control of all users and devices on the network, regardless of how they connect.
When a device connects to a Secure Access Switch Ethernet port, it is first identified, and then the user is authenticated. Once authenticated, access to the network is granted based on pre-defined security policy from the FortiGate, ensuring secure network access across the enterprise, without impacting the user experience.
Fortinet FortiSwitch 448D - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Ports
48 x 10/100/1000 + 4 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
370 W
Performance
Switching capacity: 176 Gbps , Latency: 1 µs
Virtual interfaces (VLANs): 4000 , Maximum aggregation groups: 13
MAC Address Table Size
16K entries
Remote Management Protocol
CLI
Flow control, power over Ethernet (PoE), port mirroring, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Jumbo Frames support, LLDP support, Link Aggregation Control Protocol (LACP), Management Information Base (MIB), tagged VLAN
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP)
44 cm x 31 cm x 4.4 cm
4.15 kg
Bundled Services
Enclosure Type
Rack-mountable 1U
Ports
PoE+
PoE Budget
370 W
Performance
16K entries
CLI
RAM
1 GB
Flash Memory
128 MB
Status Indicators
Power, PoE, link/activity
48 x 1000Base-TX - RJ-45 - PoE+ , 4 x 10Gbit LAN - SFP+ , 1 x 1000Base-T - RJ-45 - management , 1 x console - RJ-45
Internal power supply
Installed Qty
2
397 Watt
MTBF
10 years
UL, VCCI, BSMI, CB, FCC, RoHS2, RCM
44 cm
31 cm
4.4 cm
4.15 kg
Limited warranty - lifetime
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Other bundles
£2,678.26
Save on TP Link Smart Plug
Save £2.00
£2,702.23
Scroll to top
