BT.com
Wishlist
Fortinet FortiSwitch 424D Switch
£736.52
£736.52
Add to wishlist
Delivery
Standard Due date unavailable
FortiSwitch Secure Access switches deliver outstanding security, performance and manageability for threat conscious small to mid-sized businesses, distributed enterprises and branch offices. Tightly integrated into the FortiGate® Network Security Platform, the FortiSwitch Secure Access switches can be managed directly from the familiar FortiGate interface. This single pane of glass management provides complete visibility and control of all users and devices on the network, regardless of how they connect.
When a device connects to a Secure Access Switch Ethernet port, it is first identified, and then the user is authenticated. Once authenticated, access to the network is granted based on pre-defined security policy from the FortiGate, ensuring secure network access across the enterprise, without impacting the user experience.
Fortinet FortiSwitch 424D - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 2 x 1 Gigabit / 10 Gigabit SFP+
Performance
Switching throughput: 88 Gbps , Forwarding performance: 131 Mpps , Latency: 1 µs
Virtual interfaces (VLANs): 4000 , Maximum aggregation groups: 13
MAC Address Table Size
16K entries
Jumbo Frame Support
Routing Protocol
OSPF, BGP
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, CLI
Flow control, port mirroring, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Jumbo Frames support, LLDP support, Link Aggregation Control Protocol (LACP), Management Information Base (MIB), tagged VLAN, 1.5MB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP)
44 cm x 31 cm x 4.4 cm
4.83 kg
Bundled Services
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
Routing Protocol
OSPF, BGP
Authentication Method
RADIUS
RAM
1 GB
Flash Memory
128 MB
Status Indicators
Power, link/activity
24 x 1000Base-T - RJ-45 , 2 x 10Gbit LAN - SFP+ , 1 x console - RJ-45 , 1 x management (Gigabit LAN) - RJ-45
Internal power supply
403 Watt
MTBF
10 years
UL, VCCI, C-Tick, cUL, CB, RoHS, FCC Part 15 A
44 cm
31 cm
4.4 cm
4.83 kg
Limited warranty - lifetime
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Other bundles
£736.52
Save on TP Link Smart Plug
Save £2.00
£760.49
Scroll to top
