BT.com
Wishlist
Fortinet FortiSwitch 3032D Switch
£13,082.56
£13,082.56
Add to wishlist
Delivery
Standard Due date unavailable
FortiSwitch data center switche delivers outstanding throughput, resiliency and scalability for organizations with high performance network requirements. It is ideal for top of rack server or firewall aggregation applications, as well as enterprise network core or edge deployments, where high performance 40 GE is required. Purpose-built to meet needs of today's bandwidth intensive data centers and enterprise networks, FortiSwitch data center switche delivers high-performance with a low total cost of ownership.
Fortinet FortiSwitch 3032D - switch - 32 ports - Managed - rack-mountable
Switch - 32 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
40 Gigabit Ethernet
Ports
32 x 40 Gigabit QSFP+
Performance
Switching capacity: 1280 Gbps , Port-to-port latency: 1 µs , Forwarding performance: 2400 Mpps
Virtual interfaces (VLANs): 4000 , Maximum aggregation groups: 16 , Priority queues per port: 10
MAC Address Table Size
128K entries
Jumbo Frame Support
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, CLI
Authentication Method
Secure Shell (SSH), RADIUS
Flow control, DHCP support, VLAN support, port mirroring, IPv6 support, SNTP support, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, IPv4 support, Link Aggregation Control Protocol (LACP), Management Information Base (MIB), 12MB packet buffer, tagged VLAN
IEEE 802.3, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1AX
32 x - QSFP+ , 1 x 1000Base-T - RJ-45 - management , 1 x console - RJ-45 - management
Installed Qty
2
215.3 Watt
MTBF
10 years
43.85 cm
46 cm
4.35 cm
8.8 kg
Limited warranty - lifetime
10 - 90% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Scroll to top
