BT.com
Wishlist
Fortinet FortiSwitch 224D-POE Switch
Fortinet FortiSwitch 224D-POE...
£723.85
£723.85
Add to wishlist
Delivery
Standard Due date unavailable
The FortiSwitch-224D-POE is a 1RU form-factor switch, equipped with 20 dedicated RJ45 Gigabit Ethernet ports and 4 RJ45/SFP combo ports. Perfect for high-density distributed enterprise or SMB wire closet installations, the FortiSwitch-224D-POE provides high-speed secure access to your wired LAN network clients. The built-in Power Over Ethernet (POE) ports enable the simple and rapid installation of POE capable devices, such as wireless Access Points and IP phones, reducing your overall network TCO.
The FortiSwitch-224D-POE supports logical network segmentation and visibility, enabling the convergence of voice, data and wireless traffic onto a single network platform, while still meeting compliance requirements for data separation.
Fortinet FortiSwitch 224D-POE - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
12 x 10/100/1000 (PoE) + 12 x 10/100/1000 + 4 x shared Gigabit SFP
Power Over Ethernet (PoE)
PoE
PoE Budget
180 W
Performance
Switching throughput: 48 Gbps
Virtual interfaces (VLANs): 512
MAC Address Table Size
16000 entries
Jumbo Frame Support
Routing Protocol
OSPF, BGP
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, CLI
Authentication Method
RADIUS
Flow control, power over Ethernet (PoE), port mirroring, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Jumbo Frames support, LLDP support, Link Aggregation Control Protocol (LACP), Management Information Base (MIB), tagged VLAN
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP)
Status Indicators
Power, PoE, link/activity
12 x 1000Base-T - RJ-45 - PoE - 15.4 W , 12 x 1000Base-T - RJ-45 , 4 x - SFP , 1 x console - RJ-45
Internal power supply
AC 120/230 V (50 - 60 Hz)
225 Watt
UL, VCCI, C-Tick, cUL, CB, RoHS, FCC Part 15 A
44 cm
25.7 cm
4.4 cm
3.85 kg
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Scroll to top
