BT.com
Wishlist
Fortinet FortiSwitch 1048D Switch
£10,996.81
£10,996.81
Add to wishlist
Delivery
Standard Due date unavailable
FortiSwitch Data Center series of Ethernet LAN Switches deliver outstanding throughput, resiliency and scalability for organizations with High Performance Virtualized Data Center Networks. They are ideal for Top of Rack server or firewall aggregation applications, as well as enterprise network core or edge deployments, where high performance 10 GbE or 40 GbE is required.
FortiSwitch Data Center Switches provide a high-performance switching fabric with data center capabilities including Link Aggregation with 802.11ad and Link Aggregation Control Protocol (LAC) as well as support for large MAC address tables and jumbo frames, all with a low Total Cost of Ownership. FortiSwitch data center switches are purpose-built to meet needs of today's bandwidth intensive virtualized data centers and enterprise networks.
Fortinet FortiSwitch 1048D - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Ports
48 x 1 Gigabit / 10 Gigabit SFP+ + 4 x 40 Gigabit QSFP+
Performance
Switching capacity: 640 Gbps , Port-to-port latency: 1 µs , Forwarding performance: 1200 Mpps
Virtual interfaces (VLANs): 4000 , Maximum aggregation groups: 24 , Priority queues per port: 10
MAC Address Table Size
128K entries
Jumbo Frame Support
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, CLI
Flow control, DHCP support, VLAN support, port mirroring, IPv6 support, SNTP support, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, IPv4 support, Link Aggregation Control Protocol (LACP), Management Information Base (MIB), 9MB packet buffer, tagged VLAN
IEEE 802.3, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1AX, IEEE 802.11ad
43.85 cm x 46 cm x 4.35 cm
8.8 kg
Bundled Services
Enclosure Type
Rack-mountable 1U
Ports
Performance
128K entries
Jumbo Frame Support
Routing Protocol
Static IP routing
Authentication Method
Secure Shell (SSH), RADIUS
48 x - SFP+ , 1 x 1000Base-T - RJ-45 - management , 1 x console - RJ-45 - management , 4 x - QSFP+
Installed Qty
2
215.3 Watt
MTBF
10 years
43.85 cm
46 cm
4.35 cm
8.8 kg
Limited warranty - lifetime
10 - 90% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Scroll to top
