BT.com
Wishlist
Flexson Wall Mount for SONOS PLAY:1 - White (Single)
Delivery
Standard Due date unavailable
Tilt it, swivel it, even hang it upside down! Flexsons bespoke bracket for the SONOS PLAY: 1 allows you to wall mount your speaker in the ideal place to sound - and look - great. This improved design gives you yet more flexibility and functionality. This Flexson mount has a unique tilting mechanism, as well as the ability to swivel left or right, so you can perfectly angle your sound. The bracket also allows you to hang the PLAY: 1 upside down? So you can access its on-speaker controls even when it is mounted high up. You can even mount your speaker on the ceiling! The Flexson wall mount for SONOS PLAY: 1 is precision engineered to perfectly match the size and style of the SONOS speaker. It also allows for neat cable routing, easy fitting and flexible placement. Free up your surfaces and mount your music today!
Flexson FLXP1WB1011 - wall mount
Wall mount
3.5 cm x 6.2 cm x 12.7 cm
200 g
Recommended Use
Speaker(s)
White
Sonos PLAY:1
3.5 cm
6.2 cm
12.7 cm
200 g
White
AV Furniture
Wall mount
Mounting Components
Wall mount bracket
Recommended Use
Speaker(s)
Adjustments
Tilt
Swivel adjustment
Sonos PLAY:1
Scroll to top
