BT.com
Wishlist
Flexson Wall Mount for SONOS PLAY:1 - Black (Single)
Flexson Wall Mount for SONOS PLAY:1...
£26.65
£26.65
Add to wishlist
Delivery
Standard Due date unavailable
The Flexson FLXP1WB1021 wall bracket is the perfect choice for your Sonos Play 1 speaker. The Tilt and Swivel function allows you to set the bracket to your perfect position on either the wall or ceiling. With easy cable routing and and simple fitting this is the obvious choice for your PLAY 1 speaker.
Flexson FLXP1WB1021 - wall mount
Wall mount
3.5 cm x 6.2 cm x 12.7 cm
Tilt
200 g
Recommended Use
Speaker(s)
Sonos PLAY:1
3.5 cm
6.2 cm
12.7 cm
200 g
AV Furniture
Wall mount
Mounting Components
Wall mount bracket
Recommended Use
Speaker(s)
Tilt
Swivel adjustment
Sonos PLAY:1
Scroll to top
