BT.com
Wishlist
Flexson Cantilever Mount for SONOS PLAYBAR + TV - Black
Delivery
Standard Due date unavailable
Flexson Cantilever Mount for SONOS PLAYBAR + TV is a premium design that can hold both flatscreen TVs (37-55in) and the PLAYBAR itself, allowing both units to rotate to face the viewer. The Flexson Screen Mount fixes to your existing bracket, allowing you to slip in the SONOS PLAYBAR again, ensuring your sound moves in line with the screen. It suits all 37-55in flatscreens (all VESA mounts to 600 x 400mm).
  • Vertical and horizontal adjustment to align screen and PLAYBAR.
  • PLAYBAR appears as part of the TV and rotates in line with it.
  • Rotates up to 180° with 40" screen.
  • Fits screens 37" - 55" (all VESA mounts to 600 x 400mm ).
  • Maximum TV 40 kgs.
  • PLAYBAR can even be adjusted so that it lines up with the bottom.
Flexson Cantilever - wall mount
85 cm
7.6 cm
72.5 cm
12.5 kg
AV Furniture
Wall mount
Recommended Use
LCD / plasma panel / sound bar
Flat Panel Mount Interface
Up to 600 x 400 mm
Recommended Display Size
37"-55"
Rotation
180°
Adjustments
Horizontal
Max Load Weight
40 kg
Scroll to top
