BT.com
Wishlist
Fitbit Blaze, Slim Pink / 22k Gold Plated - Small
Free delivery
Colours:
Delivery
Standard Due date unavailable
Special Edition
Seeking a slim profile and statement wristband? The Slim Pink, 22k Gold Plated Blaze does the trick! A stainless steel frame with a gold satin finish helps your stats shine.
Get fit in style with a smart fitness watch built with revolutionary features like PurePulse® heart rate, Connected GPS, on-screen workouts and more. Need music to work out to? Music control on your Blaze allows you to adjust volume, play, pause, or switch songs from your smartphone with just a simple tap. Packed full of features like all-day activity & sleep reminders, and interchangeable accessories, Blaze keeps you active and stylish. Start your day right and wake up to a silent alarm with the Fitbit app! Or why not try a Fitstar workout on your tracker and get step-by-step coaching and instructions?
Be in control
- Control your music, straight from your Blaze™! Play, pause, skip, and adjust the volume of your songs within your mobile playlist - great for working out.
- PurePulse® lets you monitor your heart rate, with automatic wrist-based heart rate tracking! Work towards your weight goals by monitoring your heart - it's in the middle of everything you do.
- Keep going all day, with the long battery life
- The Blaze™ syncs wirelessly and automatically to computers and over 200 leading iOS, Android and Windows devices
- Smartphone notifications pop up on your screen when your phone is nearby - receive calls, texts, calendar events, and push notifications from your favourite apps! (iOS and Android)
The Blaze™ listens to your body
- Tracks your all-day activity
- Gives you reminders to move when you've been static for too long
- Find moments out of calm throughout your day with personalised breathing sessions based on your heart rate
- Auto sleep tracking, silent alarms & sleep stages automatically track your sleep quality, allow you to wake up peacefully, and gain insight into every stage of your sleep! Get a better understanding of your sleep quality.
Your new personal trainer
- Track workouts like running, biking, and weights, and get real time stats on the display!
- Workout summaries allow you to track improvements, straight from your wrist
- SmartTrack™ automatically recognises select activities and records it in the exercise section of the Fitbit app
- With connected GPS, see real-time stats like pace and distance
- Get a better understanding of your cardio fitness level and see how you can improve over time with your very own fitness score!
- On-Screen Workouts give you step by step instructions that can coach you through every move
Be you
Accessory bands & frames are availabe for when you'd like to customise your Blaze™ to suit your own personal style.
Fitbit Blaze - gold - smart watch with band - slim pink
Smart watch
Bluetooth
Supported Host Device OS
iOS, Android, Windows Phone
Display
LCD
Input
Touch screen
Tracking Data
Distance, time, calories burned, activity, sleep activity, heart rate, steps taken, floors climbed
Band
Slim pink - band - elastomer - 140-170 mm - (S)
Heart rate sensor, missed calls notification, music remote handling, calendar notification, SMS notification, HR zones, PurePulse heart rate technology, changeable band, automatic exercise recognition, changeable frame
Battery Run Time
Up to 5 day(s)
Case Material
Stainless steel
42 mm
44 g
1 year warranty
Smart watch
Integrated Components
Heart rate sensor
Tracking Data
Missed calls notification, music remote handling, calendar notification, SMS notification, HR zones, PurePulse heart rate technology, changeable band, automatic exercise recognition, changeable frame, ambient light sensor, altimeter, three-axis accelerometer
Display
LCD - colour
Wireless Interface
Bluetooth 4.0
Input Device
Touch sensitive screen
Lithium polymer
Run Time (Up To)
5 day(s)
Recharge Time
2 hour(s)
Band
Name
Band
Size
S
Fits Wrist Size
140-170 mm
Clasp Type
Buckle
Material
Elastomer
Slim pink
42 mm
44 g
Preloaded Software
Clock, Silent alarm
System Requirements for PC Connection
Microsoft Windows Vista or later, Apple MacOS X 10.6 or later
Vibrating Alert
Body Material
Stainless steel
Protection
Weatherproof, splashproof, sweatproof
USB charging cable
Warranty
1 year warranty
-10 °C
60 °C
Max Altitude Operating
8535 m
Scroll to top
