BT.com
Wishlist
EVGA SUPERNOVA 750w G1 GOLD 80+ Modular PSU
Delivery
Standard Due date unavailable
The EVGA SuperNOVA 750 Power Supply is here with Gold Rated Efficiency. Designed with enthusiast needs in mind the SuperNOVA series are the best choice to power next generation enthusiast computers. Combining 750W of continuous power with exceptional performance, stunning efficiency, and cutting-edge design and features, the SuperNOVA series power supplies are what you need to take your system to the next level.
EVGA SuperNOVA 750 G1 - power supply - 750 Watt
Power supply - internal
Specification Compliance
ATX12V / EPS12V
80 PLUS Certification
80 PLUS Gold
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Input Connectors
Power IEC 60320 C14
Output connectors
1 x power 24 pin ATX , 2 x power 8 pin +12V with detachable 4 pin section , 4 x 8 pin PCI Express power with detachable 2 pin section , 9 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 1 x 4 PIN mini-power connector
10 years warranty
ATX12V / EPS12V
PSU Form Factor
ATX
Input Voltage
AC 100-240 V
Frequency Required
50/60 Hz
Input Connectors
Power IEC 60320 C14
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V1 - 20 A , +12V2 - 20 A , +12V3 - 20 A , +12V4 - 20 A , +5VSB - 3 A , -12V - 0.8 A
Efficiency
90% (115VAC) / 92% (220-240VAC)
Modular Cable Management
80 PLUS Gold
Power cable - external - 1.8 m
Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection
Limited warranty - 10 years
Scroll to top
