BT.com
Wishlist
EVGA SuperNOVA 550 G2 550W Gold Fully Modular PSU
Delivery
Standard Due date unavailable
The unbeatable performance of the SVGA SuperNOVA G2 power supply line is now available in 550 watt. Based on the award winning G2 power supplies, these units feature 80 Plus Gold rated efficiency, and clean, continuous power to every component. The ECO control fan system offers fan modes to provide absolutely zero fan noise during load to medium load operations. Backed by 100% Japanese capacitor design, the SVGA SuperNOVA 550 G2 power supplies offer unbeatable performance at an unbeatable value.
EVGA SuperNOVA 550 G2 - power supply - 550 Watt
Power supply - internal
80 PLUS Certification
80 PLUS Gold
2.72 kg
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
550 Watt
Output connectors
1 x power 24 pin ATX , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 9 x 15 pin Serial ATA power , 3 x 4 PIN internal power , 1 x 4 PIN mini-power connector , 2 x 8 pin PCI Express power with detachable 2 pin section , 1 x 8 pin PCI Express power
Cooling System
140 mm fan
15 cm x 16.5 cm x 8.5 cm
7 years warranty
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
550 Watt
Output Current
+3.3V - 22 A , +5V - 22 A , +12V - 45.8 A , +5VSB - 3 A , -12V - 0.5 A
Efficiency
90% (115VAC) / 92% (220-240VAC)
80 PLUS Gold
Power cable - external - 1.5 m , Power 24 pin ATX modular cable 60 cm , Power 8 pin EPS12V modular cable 70 cm , 2 x PCI Express power cable , 3 x power 15 pin SATA to 4 pin cable , Floppy adapter , Power cable
MTBF
100,000 hour(s)
Cooling System
140 mm fan
Over current protection, over voltage protection, SLI ready, CrossFire ready, undervoltage protection, short-circuit protection, single 12V rail, dual ball bearing cooling fan, ECO Intelligent Thermal Control System, Eco-Mode
BSMI, CB, FCC, RoHS, WEEE, cTUVus, ErP 2013, RCM
Limited warranty - parts and labour - 7 years
50 °C
15 cm
16.5 cm
8.5 cm
2.72 kg
Scroll to top
