BT.com
Wishlist
EVGA GeForce GTX 950 Superclocked+ ACX2.0 Gaming 2GB GDDR5 PCIe3.0 Graphics Card
Delivery
Standard Due date unavailable
PLAY THE FUTURE - GeForce® GTX™ 950
The GeForce GTX 950 is a true gaming GPU designed for every PC gamer. It’s built to the exacting specifications of the GeForce GTX family and powered by NVIDIA Maxwell™—the most advanced GPU architecture ever created—to deliver 3x the performance of previous-generation cards.
The GeForce GTX 950 transforms your PC into a gaming rig to rival any game console. Enjoy fast and responsive MOBA gaming and the latest games in 1080p. Plus, it delivers a more interactive and cinematic experience with advanced visual effects driven by NVIDIA GameWorks™ and advanced DirectX 12.
FULL HD PERFORMANCE
Maxwell’s exceptional performance and efficiency means you can transform your basic PC into a modern gaming rig that can play the latest games at 1080p.
STEP ABOVE A CONSOLE
More powerful than any console, this card delivers a truly interactive, cinematic experience in the latest games with advanced effects driven by NVIDIA GameWorks™ and DirectX™ 12.
GET THE EDGE FOR MOBA
Competitive gamers demand instant responsiveness and low latency. The GeForce GTX 950 is designed from the ground up for the MOBA gamer, giving you the power and performance to rule the game.
NEW WAYS TO PLAY
GeForce Experience™ makes it easy to share your gameplay or co-play online with friends. With GeForce GTX, stream PC games to your NVIDIA® SHIELD™ devices using NVIDIA GameStream™.
Ready to get real about gaming? Experience the performance of the new GeForce GTX 950.
EVGA GeForce GTX 950 Superclocked+ ACX 2.0 - graphics card - GF GTX 950 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 950
2 GB GDDR5
Core Clock
1165 MHz
Boost Clock
1355 MHz
CUDA Cores
768
Effective Memory Clock
6.61 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
HDMI , 3 x DisplayPort , DVI-I (dual link)
API Supported
OpenCL, OpenGL 4.4, DirectX 12
25.65 cm x 11.115 cm
3 years warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1165 MHz
Boost Clock
1355 MHz
CUDA Cores
768
Max Resolution
4096 x 2160 at 240 Hz
4
API Supported
Nvidia CUDA technology, Nvidia Surround technology, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost 2.0, NVIDIA G-Sync ready, NVIDIA GameStream, NVIDIA Dynamic Super Resolution technology, NVIDIA MFAA technology, NVIDIA GameWorks, eVGA Active Cooling Xtreme (ACX) 2.0, Straight heatpipes (SHP), Optimized Power Target (OPT), dB Noise Inverter (dbi)
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.61 GHz
Bus Width
128-bit
Bandwidth
105.76 GBps
Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 10 (32/64 bits), Microsoft Windows 7 / 8 (32/64 bits)
Required Power Supply
350 W
Additional Requirements
6 pin PCI Express power connector
110 Watt
Software Included
EVGA Precision X, EVGA OC Scanner X
25.65 cm
11.115 cm
Limited warranty - 3 years
Scroll to top
