Click to visit BT.com
BT.com
Wishlist
EVGA GeForce GTX 780 3GB PCI-Express 3.0 HDMI
Quicklinx: 8Q49WS00
Mfr#: 03G-P4-2781-KR
The EVGA GeForce GTX 780 marks an evolution in gaming performance - an insanely fast, smooth, and whisper-quiet experience, every time.
Get the best gaming, with NVIDIA GeForce Experience™ one-click drivers and settings."
  • 2304 CUDA Cores
  • Base Clock: 863 MHz
  • Boost Clock: 902 MHz
  • Bus: PCI-E 3.0
  • 2-way, 3-way SLI Ready
  • Texture Fill Rate: 165.6 GT/s
  • Memory Detail: 3072 MB GDDR5
  • Memory Bit Width: 384 Bit
  • Memory Clock: 6008 MHz
  • Memory Speed: 0.33 ns
  • Memory Bandwidth: 288.38 GB/s
Key Features
  • NVIDIA TXAA Technology
  • NVIDIA GPU Boost 2.0
  • NVIDIA PhysX Technology
  • NVIDIA FXAA Technology
  • NVIDIA Adaptive Vertical Sync
  • NVIDIA Surround
  • Support for four concurrent displays; two dual-link DVI connectors, HDMI and Displayport 1.2
  • Microsoft DirectX 11.1 API (feature level 11_0) with Direct Compute 5.0 support
  • NVIDIA 3D Vision Ready
  • NVIDIA SLI Ready
  • NVIDIA CUDA Technology
  • PCI Express 3.0 Support
  • OpenGL 4.3 Support
  • OpenCL Support
  • 6+2 Power Phases
EVGA GeForce GTX 780 graphics card - GF GTX 780 - 3 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 780
3 GB - GDDR5
Core Clock
863 MHz
Boost Clock
902 MHz
CUDA Cores
2304
Effective Memory Clock
6.008 GHz
Memory Interface
384-bit
Max Resolution
4096 x 2160
DVI-I , DVI-D , HDMI , DisplayPort , VGA - with adapter
API Supported
OpenCL, DirectCompute 5.0, OpenGL 4.2, DirectX 11.1, OpenGL 4.3
26.67 cm x 11.115 cm
3 years warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
863 MHz
Boost Clock
902 MHz
CUDA Cores
2304
Max Resolution
4096 x 2160
API Supported
Nvidia GeForce 3D Vision Ready, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia Surround technology, Nvidia SLI ready, TXAA, FXAA, NVIDIA Adaptive Vertical Sync, Nvidia SMX Engine, NVIDIA GPU Boost 2.0, NVIDIA Project SHIELD Ready
Size
3 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
384-bit
Bandwidth
288.38 GBps
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
Required Power Supply
600 W
Additional Requirements
6-pin + 8-pin power connectors
250 Watt
8 pin to 4 pin power cable, 6 pin to 4 pin power cable, EVGA Accessory Pack
1 x DVI-VGA adapter
Software Included
Drivers & Utilities
26.67 cm
11.115 cm
1.36 kg
3 years warranty
Service & Support Details
Limited warranty - 3 years
Resources
The following resources are available for the EVGA GeForce GTX 780 3GB PCI-Express 3.0 HDMI
