BT.com
Wishlist
EVGA GeForce GTX 760 1085MHz 2GB PCI-Express 3.0 HDMI Superclocked
Delivery
Standard 1-3 working days
The EVGA GeForce GTX 760 is the new weapon of choice for gamers - a powerful graphics card that gives you the fast, smooth, quiet gaming you're looking for in all your favorite titles.
EVGA is also extending the award winning ACX Cooling to the EVGA GeForce GTX 760 line. With a 40% increase in heatsink volume, the EVGA ACX is more efficient at dissipating heat, allowing for 15% lower GPU temperatures.
Even the fan blades are of the highest quality; with a 700% increase in strength, and 25% lower weight when compared to competitors. This makes the fans 20% more efficient by requiring lower power levels. EVGA is also using double ball bearing fans which offer a 12 year lifespan, 4X longer when compared to competitors!
Core
  • 1152 CUDA Cores
  • Base Clock: 1072 MHz
  • Boost Clock: 1137 MHz
  • Bus: PCI-E 3.0
  • 2-way, 3-way SLI Ready
  • Texture Fill Rate: 102.9 GT/s
  • Memory Detail: 2048 MB GDDR5
  • Memory Bit Width: 256 Bit
  • Memory Clock: 6008 MHz
  • Memory Speed: 0.33 ns
  • Memory Bandwidth: 192.2 GB/s
Key Features
  • NVIDIA TXAA Technology
  • NVIDIA GPU Boost 2.0
  • NVIDIA PhysX Technology
  • NVIDIA FXAA Technology
  • NVIDIA Adaptive Vertical Sync
  • NVIDIA Surround
  • Support for four concurrent displays; two dual-link DVI connectors, HDMI and Displayport 1.2
  • Microsoft DirectX 11.1 API (feature level 11_0) with Direct Compute 5.0 support
  • NVIDIA 3D Vision Ready
  • NVIDIA SLI Ready
  • NVIDIA CUDA Technology
  • PCI Express 3.0 Support
  • OpenGL 4.3 Support
  • OpenCL Support
EVGA GeForce GTX 760 Superclocked graphics card - GF GTX 760 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 760
2 GB GDDR5
Core Clock
1072 MHz
Boost Clock
1137 MHz
CUDA Cores
1152
Effective Memory Clock
6.008 GHz
Memory Interface
256-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
DVI-I (dual link) , DVI-D (dual link) , HDMI , DisplayPort , VGA - with adapter
API Supported
OpenCL, DirectCompute 5.0, DirectX 11.1, OpenGL 4.3
24.1 cm x 11.115 cm
3 years warranty with product registration
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1072 MHz
Boost Clock
1137 MHz
CUDA Cores
1152
Max Resolution
4096 x 2160
4
API Supported
Nvidia 3-way SLI ready, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, x.v.Color technology, Deep Color technology, Blu-Ray 3D Support, TXAA, NVIDIA Adaptive Vertical Sync, Nvidia Fast Approximate Antialiasing Technology (FXAA), Nvidia SMX Engine, NVIDIA GPU Boost 2.0, NVIDIA Project SHIELD Ready
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
256-bit
Bandwidth
192.2 GBps
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
Required Power Supply
500 W
Additional Requirements
6-pin + 8-pin power connectors
170 Watt
Dual 6-pin PCIe to 8-pin power adapter, EVGA Accessory Pack, Dual 4 pin to 6 pin power cable
1 x DVI-VGA adapter
Software Included
Drivers & Utilities, EVGA Precision X, EVGA OC Scanner X
24.1 cm
11.115 cm
1.36 kg
Limited warranty - 3 years
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great Motherboard
Reviewed by Robert on 24/01/2014
I was expecting a decent board but I am running my i7 4770k at 4.8Ghz and my ram is at 2800Mhz and all is running amazingly stable.
Will recommend this board, its as good as the higher priced boards out there.
Scroll to top
