Click to visit BT.com
BT.com
Wishlist
EVGA GeForce GTX 680 1111MHz 4GB PCI-Express 3.0 HDMI Classified
Quicklinx: 87Q3WS00
Mfr#: 04G-P4-3688-KR
Get to the next level with the EVGA GeForce GTX 680. This card delivers truly game-changing performance that taps into the powerful new GeForce architecture to redefine smooth, seamless, lifelike gaming. It offers brand new, never before seen features that will redefine the way you think about performance graphics cards. Expect more from your graphics card than just state-of-the-art features and technology; get a faster, smoother and richer gaming experience with the EVGA GeForce GTX 680.
No 1 American Nvidia Brand, EVGA warranty allows for overclocking, the consumer can replace the reference cooler for better overclocking and as long as they return the original cooler with the card then it will be covered by the EVGA warranty. There is Direct RMA with a 7 working day turn around, Step-up programme enables consumers to upgrade their graphics card within 3 months of purchase and only pay the difference for the more expensive card. EVGA forum offers advice, driver updates and special offers and the EVGA GPU purchase gives enthusiasts free online gaming with EVGA gaming servers.
  • Nvidia SMX Engine
  • Nvidia GPU Boost
  • Nvidia Adaptive Vertical Sync
  • Nvidia Surround
  • Support for four concurrent displays; two dual-link DVI connectors, HDMI and Displayport 1.2
  • Microsoft DirectX 11 with Direct Compute 5.0 support
  • Nvidia PhysX Technology
  • Nvidia 3D Vision-Ready
  • Nvidia SLI-Ready
  • Nvidia CUDA Technology
  • PCI Express 3.0 Support
  • OpenGL 4.2 Support
  • OpenCL Support
  • One EVBot connector
  • 3 Year Manufacturers Warranty (extended to 10 Years if card is registered with EVGA within 30 days of purchase)
Specification
  • Base Clock: 1111 MHz
  • Boost Clock: 1176 MHz
  • Memory Clock: 6008 MHz Effective
  • CUDA Cores: 1536
  • Bus Type: PCI-E 3.0
  • Memory Detail: 4096MB GDDR5
  • Memory Bit Width: 256 Bit
  • Memory Speed: 0.33ns
  • Memory Bandwidth: 192.25 GB/s
  • Texture Fill Rate: 138 GT/s
EVGA GeForce GTX 680 Classified graphics card - GF GTX 680 - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 680
4 GB GDDR5
Core Clock
1111 MHz
Boost Clock
1176 MHz
CUDA Cores
1536
Effective Memory Clock
6.008 GHz
Memory Interface
256-bit
Max Resolution
2560 x 1600
HDMI , DVI-I (dual link) , DisplayPort , DVI-D (dual link) , VGA - with adapter
API Supported
DirectX 11, OpenCL, DirectCompute 5.0, OpenGL 4.2
26.67 cm x 15.088 cm
3 years warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1111 MHz
Boost Clock
1176 MHz
CUDA Cores
1536
Max Resolution
2560 x 1600
API Supported
Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, Nvidia SLI ready, TXAA, SMX technology, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost, Nvidia Fast Approximate Antialiasing Technology (FXAA)
Size
4 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
256-bit
Bandwidth
192.25 GBps
Microsoft Windows Vista / XP / 7, Microsoft Windows Vista / XP / 7 (64-bit versions)
Required Power Supply
550 W
1 x DVI-VGA adapter
Software Included
Drivers & Utilities, EVGA Precision
26.67 cm
15.088 cm
1.36 kg
3 years warranty
Service & Support Details
Limited warranty - 3 years
