BT.com
Wishlist
EVGA GeForce GTX 680 1058MHz 2GB PCI-Express 3.0 HDMI SuperClocked
Delivery
Standard Due date unavailable
Get to the next level with the EVGA GeForce GTX 680. The card delivers truly game-changing performance that taps into the powerful new GeForce architecture to redefine smooth, seamless, lifelike gaming. It offers brand new, never before seen features that will redefine that way you think about performance graphics cards. Expect more from your graphics card than just state-of-the-art features and technology; get a faster, smoother and richer gaming experience with the EVGA GeForce GTX 680.
No 1 American Nvidia Brand, EVGA warranty allows for overclocking, the consumer can replace the reference cooler for better overclocking and as long as they return the original cooler with the card then it will be covered by the EVGA warranty. There is Direct RMA with a 7 working day turn around, Step-up programme enables consumers to upgrade their graphics card within 3 months of purchase and only pay the difference for the more expensive card. EVGA forum offers advice, driver updates and special offers and the EVGA GPU purchase gives enthusiasts free online gaming with EVGA gaming servers.
  • Nvidia SMX Engine
  • Nvidia GPU Boost
  • Nvidia Adaptive Vertical Sync
  • Nvidia Surround
  • Support for four concurrent displays; two dual-link DVI connectors, HDMI and Displayport 1.2
  • Microsoft DirectX 11 with Direct Compute 5.0 support
  • Nvidia PhysX Technology
  • Nvidia 3D Vision-Ready
  • Nvidia SLI-Ready
  • Nvidia CUDA Technology
  • PCI Express 3.0 Support
  • OpenGL 4.2 Support
  • OpenCL Support
  • 3 Year Manufacturers Warranty
  • Base Clock: 1058 MHz
  • Boost Clock: 1124 MHz
  • Memory Clock: 6208 MHz Effective
  • CUDA Cores: 1536
  • Bus Type: PCI-E 3.0
  • Memory Detail: 2048MB GDDR5
  • Memory Bit Width: 256 Bit
  • Memory Speed: 0.33ns
  • Memory Bandwidth: 198.66 GB/s
  • Texture Fill Rate: 135.4 GT/s
EVGA GeForce GTX 680 Superclocked graphics card - GF GTX 680 - 2048 MB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 680
2048 MB - GDDR5
Core Clock
1058 MHz
CUDA Cores
1536
Effective Memory Clock
6.208 GHz
Memory Interface
256-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / DisplayPort: 2560 x 1600 / HDMI: 2560 x 1600 / VGA: 2048 x 1536
Max Monitors Supported
4
DVI-I , DVI-D , HDMI , DisplayPort , VGA - with adapter
API Supported
DirectX 11, OpenCL, DirectCompute 5.0, OpenGL 4.2
25.4 cm x 12.1 cm
3 years warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1058 MHz
CUDA Cores
1536
Max Resolution
2560 x 1600 at 240 MHz
4
API Supported
Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, Nvidia SLI ready, TXAA, GPU Boost technology, Adaptive V-Sync, FXAA, SMX technology , HDCP
Size
2048 MB
GDDR5 SDRAM
Effective Clock Speed
6.208 GHz
Bus Width
256-bit
Bandwidth
198.66 GBps
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
Required Power Supply
550 W
Additional Requirements
CD-ROM, adjacent PCI slot, PCIe slot, two 6-pin power connectors
2 x dual 4 pin to 6 pin power cables
Software Included
Drivers & Utilities
25.4 cm
12.1 cm
1.36 kg
3 years warranty
Service & Support Details
Limited warranty - 3 years
Resources
The following resources are available for the EVGA GeForce GTX 680 1058MHz 2GB PCI-Express 3.0 HDMI SuperClocked
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Fast !!!
Reviewed by Dom on 31/08/2012
This is my first purchase from BT and its exactly what i was looking for, cheaper than the other stores by a good £30, was delivered late by their yodel service by a man in a tracksuit who looked like he just rolled in mud, looked quite unprofessional, ill wait for BT to change their delivery service to someone much better like DPD before i order anything from them again.
Scroll to top
