BT.com
Wishlist
EVGA GeForce GTX 660 Ti 1046MHz 2GB PCI-E 3.0 HDMI FTW Signature 2
Delivery
Standard Due date unavailable
Introducing the weapon of choice for gamers - the EVGA GeForce GTX 660 Ti. It adds a new dimension to the NVIDIA Kepler-powered family of graphics cards by delivering the ideal fusion of power, performance, and affordability. Experience faster, smoother, richer gaming with innovative NVIDIA technologies like TXAA antialiasing, Adaptive Vertical Sync, and PhysX.'
Performance
  • NVIDIA GTX 660 Ti
  • 1344 CUDA Cores
  • 1046 MHz GPU
  • 1124 MHz Boost Clock
  • 2048 MB, 192 bit GDDR5
  • 6008 MHz (effective)
  • 144.19 GB/s Memory Bandwidth
  • PCI-E 3.0 16x
  • DVI-I, DVI-D, HDMI, Display-Port
  • SLI Capable
Resolution & Refresh
  • 240Hz Max Refresh Rate
  • Max Analog : 2048x1536
  • Max Digital : 2560x1600 (Dual Link DVI Only)
Operating System Support
  • Windows 8 32/64bit
  • Windows 7 32/64bit
  • Windows Vista 32/64bit
  • Windows XP 32/64bit
Requirements
  • Minimum of a 450 Watt power supply. (Minimum recommended power supply with +12 Volt current rating of 24 Amps.)
  • Two available 6-pin PCI-E power dongles
EVGA GeForce GTX 660 Ti FTW Signature 2 - graphics card - GF GTX 660 Ti - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 660 Ti
2 GB GDDR5
Core Clock
1046 MHz
Boost Clock
1124 MHz
CUDA Cores
1344
Effective Memory Clock
6.008 GHz
Memory Interface
192-bit
Max Resolution
2560 x 1600
Max Monitors Supported
4
DVI-D (dual link) , DVI-I (dual link) , DisplayPort , HDMI , VGA - with adapter
API Supported
DirectX 11, OpenCL, DirectCompute 5.0, OpenGL 4.2
25.4 cm x 11.115 cm
3 years warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1046 MHz
Boost Clock
1124 MHz
CUDA Cores
1344
Max Resolution
2560 x 1600
4
API Supported
Nvidia GeForce 3D Vision Ready, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia Surround technology, Nvidia SLI ready, TXAA, FXAA, SMX technology, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
192-bit
Bandwidth
144.19 GBps
Microsoft Windows Vista / XP / 7, Microsoft Windows Vista / XP / 7 (64-bit versions)
Required Power Supply
450 W
Additional Requirements
PCIe slot, two 6-pin power connectors
2 x 6 pin power cables, EVGA Accessory Pack
1 x DVI-VGA adapter
Software Included
Drivers & Utilities, EVGA Precision X, EVGA OC Scanner X
25.4 cm
11.115 cm
1.36 kg
Limited warranty - parts and labour - 3 years , Product info support - web support
Scroll to top
