Click to visit BT.com
BT.com
Wishlist
EVGA GeForce GTX 660 993MHz 2GB PCI-Express 3.0 HDMI
4.0*
Quicklinx: 8GF1WS00
Mfr#: 02G-P4-2660-KR
Get the weapon of choice for gamers - the EVGA GeForce GTX 660. It takes NVIDIA Kepler-powered graphics cards to new levels of affordability while retaining class-leading performance and power efficiency, making it a must-have upgrade for today's hottest games. The EVGA GeForce GTX 660 graphics card represents the Kepler "sweet spot" for gamers - the ultimate combination of performance, power efficiency, and affordability.
Performance
  • NVIDIA GTX 660
  • 960 CUDA Cores
  • 993 MHz GPU
  • 1058 MHz Boost Clock
  • 2048 MB, 192 bit GDDR5
  • 6008 MHz (effective)
  • 144.19 GB/s Memory Bandwidth
  • PCI-E 3.0 16x
  • DVI-I, DVI-D, HDMI, Display-Port
  • SLI Capable
Resolution & Refresh
  • 240Hz Max Refresh Rate
  • Max Analog : 2048x1536
  • Max Digital : 2560x1600 (Dual Link DVI Only)
Operating System Support
  • Windows 8 32/64bit
  • Windows 7 32/64bit
  • Windows Vista 32/64bit
  • Windows XP 32/64bit
Requirements
  • Minimum of a 450 Watt power supply. (Minimum recommended power supply with +12 Volt current rating of 24 Amps.)
  • Total Power Draw : 140 Watts
Product Warranty
  • This product comes with a 3 year warranty. Registration is recommended.
EVGA GeForce GTX 660 graphics card - GF GTX 660 - 2 GB
Graphics card
Bus Type
PCI Express 3.0
Graphics Engine
NVIDIA GeForce GTX 660
2 GB GDDR5
Core Clock
993 MHz
Boost Clock
1059 MHz
CUDA Cores
960
Effective Memory Clock
6.008 GHz
Memory Interface
192-bit
Max Monitors Supported
4
DVI-D (dual link) , DVI-I (dual link) , DisplayPort , HDMI , VGA - with adapter
API Supported
DirectX 11, OpenGL 4.2
24.1 cm x 11.115 cm
3 years warranty
Graphics card
Bus Type
PCI Express 3.0
Graphics Engine
Core Clock
993 MHz
Boost Clock
1059 MHz
CUDA Cores
960
4
API Supported
Nvidia GeForce 3D Vision Ready, Nvidia CUDA technology, Nvidia PhysX-Ready, Nvidia Surround technology, Nvidia SLI ready, SMX technology, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost, Kepler GPU Architecture
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
192-bit
Bandwidth
144.19 GBps
Microsoft Windows Vista / XP / 7
Required Power Supply
450 W
Additional Requirements
Adjacent PCI slot
6 pin power cable, EVGA Accessory Pack
1 x DVI-VGA adapter
Software Included
Drivers & Utilities, EVGA Precision X, EVGA OC Scanner X
24.1 cm
11.115 cm
1.36 kg
3 years warranty
Service & Support Details
Limited warranty - parts and labour - 3 years , Product info support - web support
Customer reviews
Write a review for the EVGA GeForce GTX 660 993MHz 2GB PCI-Express 3.0 HDMI here!
adequate for my needs but lowest rated part in my rig
Reviewed by Anonymous Review Posted 12/11/2013
I am more than happy with the performance of this kit, installed easy and worked out the box with drivers supplied on windows 8.
Im not a power graphics user so works for me, bht it is the lowest rated thing in my otherwise top end system on the windows experience rating.
Would recommend though.
  • Overall 4*
  • Ease of use 5*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
