BT.com
Wishlist
EVGA GeForce GTX 660 993MHz 2GB PCI-Express 3.0 HDMI
Free delivery
Delivery
Standard Due date unavailable
Get the weapon of choice for gamers - the EVGA GeForce GTX 660. It takes NVIDIA Kepler-powered graphics cards to new levels of affordability while retaining class-leading performance and power efficiency, making it a must-have upgrade for today's hottest games. The EVGA GeForce GTX 660 graphics card represents the Kepler "sweet spot" for gamers - the ultimate combination of performance, power efficiency, and affordability.
Performance
  • NVIDIA GTX 660
  • 960 CUDA Cores
  • 993 MHz GPU
  • 1058 MHz Boost Clock
  • 2048 MB, 192 bit GDDR5
  • 6008 MHz (effective)
  • 144.19 GB/s Memory Bandwidth
  • PCI-E 3.0 16x
  • DVI-I, DVI-D, HDMI, Display-Port
  • SLI Capable
Resolution & Refresh
  • 240Hz Max Refresh Rate
  • Max Analog : 2048x1536
  • Max Digital : 2560x1600 (Dual Link DVI Only)
Operating System Support
  • Windows 8 32/64bit
  • Windows 7 32/64bit
  • Windows Vista 32/64bit
  • Windows XP 32/64bit
Requirements
  • Minimum of a 450 Watt power supply. (Minimum recommended power supply with +12 Volt current rating of 24 Amps.)
  • Total Power Draw : 140 Watts
Product Warranty
  • This product comes with a 3 year warranty. Registration is recommended.
EVGA GeForce GTX 660 graphics card - GF GTX 660 - 2 GB
Graphics card
Bus Type
PCI Express 3.0
Graphics Engine
NVIDIA GeForce GTX 660
2 GB GDDR5
Core Clock
993 MHz
Boost Clock
1059 MHz
CUDA Cores
960
Effective Memory Clock
6.008 GHz
Memory Interface
192-bit
Max Monitors Supported
4
DVI-D (dual link) , DVI-I (dual link) , DisplayPort , HDMI , VGA - with adapter
API Supported
DirectX 11, OpenGL 4.2
24.1 cm x 11.115 cm
3 years warranty
Graphics card
Bus Type
PCI Express 3.0
Graphics Engine
Core Clock
993 MHz
Boost Clock
1059 MHz
CUDA Cores
960
4
API Supported
Nvidia GeForce 3D Vision Ready, Nvidia CUDA technology, Nvidia PhysX-Ready, Nvidia Surround technology, Nvidia SLI ready, SMX technology, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost, Kepler GPU Architecture
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
192-bit
Bandwidth
144.19 GBps
Microsoft Windows Vista / XP / 7
Required Power Supply
450 W
Additional Requirements
Adjacent PCI slot
6 pin power cable, EVGA Accessory Pack
1 x DVI-VGA adapter
Software Included
Drivers & Utilities, EVGA Precision X, EVGA OC Scanner X
24.1 cm
11.115 cm
1.36 kg
3 years warranty
Service & Support Details
Limited warranty - parts and labour - 3 years , Product info support - web support
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* adequate for my needs but lowest rated part in my rig
Reviewed by Anonymous on 12/11/2013
I am more than happy with the performance of this kit, installed easy and worked out the box with drivers supplied on windows 8.
Im not a power graphics user so works for me, bht it is the lowest rated thing in my otherwise top end system on the windows experience rating.
Would recommend though.
Scroll to top
