Click to visit BT.com
BT.com
Wishlist
EVGA GeForce GTX 650 Ti BOOST 1072MHz 1GB PCI-Express 3.0 HDMI Superclocked
Quicklinx: 8QJ0WS00
Mfr#: 01G-P4-3656-KR
The EVGA GeForce GTX 650 Ti BOOST gives you 66% more memory bandwidth, NVIDIA SLI, and NVIDIA GPU Boost technology that dynamically maximizes clock speeds, delivering class-leading performance to the GTX 650 family. Plus, this GPU offers up to an impressive 30% performance improvement, so you can play all your favorite games at Full-HD resolutions and high quality settings.
Performance
  • NVIDIA GTX 650 Ti BOOST
  • 768 CUDA Cores
  • 1072 MHz Base Clock
  • 1137 MHz Boost Clock
  • 68.6GT/s Texture Fill Rate
  • 1024 MB, 192 bit GDDR5
  • 5012 MHz (effective)
  • 120.28 GB/s Memory Bandwidth
  • PCI-E 3.0 16x
  • DVI-I, DVI-D, Mini-HDMI, DisplayPort
Resolution & Refresh
  • 240Hz Max Refresh Rate
  • Max Analog : 2048x1536
  • Max Digital : 2560x1600 (Dual Link DVI Only)
Operating System Support
  • Windows 8 32/64bit
  • Windows 7 32/64bit
  • Windows Vista 32/64bit
  • Windows XP 32/64bit
Requirements
  • Minimum of a 450 Watt power supply. (Minimum recommended power supply with +12 Volt current rating of 24 Amps.)
  • Total Power Draw : 140 Watts
  • NVIDIA PhysX technology
  • NVIDIA 3D Vision Ready
  • NVIDIA SLI Ready
  • NVIDIA CUDA Technology
  • NVIDIA SMX Engine
  • PCI Express 3.0 Support
  • NVIDIA GPU Boost
  • OpenGL 4.2 Support
  • NVIDIA Adaptive Vertical Sync
  • OpenCL Support
  • NVIDIA Surround
  • NVIDIA FXAA Technology
  • Supports four concurrent displays
  • NVIDIA TXAA Technology
  • Microsoft DirectX 11.1 API (feature level 11_0) with Direct Compute 5.0 support
  • NVIDIA PureVideo HD Technology
EVGA GeForce GTX 650 Ti BOOST Superclocked graphics card - GF GTX 650 Ti Boost - 1 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 650 Ti Boost
1 GB - GDDR5
Core Clock
1072 MHz
Boost Clock
1137 MHz
CUDA Cores
768
Effective Memory Clock
5.012 GHz
Memory Interface
192-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / VGA: 2048 x 1536
DVI-I (dual link) , DVI-D (dual link) , Mini-HDMI , DisplayPort , VGA - with adapter
API Supported
DirectCompute 5.0, DirectX 11.1, OpenGL 4.3
24.1 cm x 11.115 cm
3 years warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1072 MHz
Boost Clock
1137 MHz
CUDA Cores
768
Max Resolution
2560 x 1600
API Supported
Nvidia CUDA technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost, Nvidia SMX Engine
Size
1 GB
GDDR5 SDRAM
Effective Clock Speed
5.012 GHz
Bus Width
192-bit
Bandwidth
120.28 GBps
Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
Required Power Supply
450 W
140 Watt
6 pin PCIe power cable
1 x DVI-VGA adapter
Software Included
Drivers & Utilities, EVGA Precision X, EVGA OC Scanner X
24.1 cm
11.115 cm
1.36 kg
3 years warranty
Service & Support Details
Limited warranty - parts and labour - 3 years , Technical support
