BT.com
Wishlist
EVGA 850W SuperNOVA Gold PSU
Delivery
Standard Due date unavailable
Ready for 4th Generation Intel Core Processors (C6/C7 Idle Mode)
Unleash the next generation in power with the EVGA SuperNOVA 850 G2 Power Supply. Based on the award winning G2 series Power Supplies from EVGA, this PSU features 80 PLUS Gold rated efficiency, and clean, continuous power to every component. This provides improved efficiency for longer operation, less power consumption, reduced energy costs and minimal heat dissipation. The new ECO Thermal Control Fan System offers fan modes to provide zero fan noise during low load operations. Backed by a 10 year warranty and Japanese capacitor design, the EVGA SuperNOVA 850 G2 is not only the right choice for your system today, it is also the best choice for your system tomorrow.
  • Unbeatable 10 Year Warranty and unparalleled EVGA Customer Support
  • 80 PLUS Gold certified, with up to 90% efficiency under typical loads
  • Highest quality Japanese brand capacitors ensure long-term reliability
  • Fully Modular to reduce clutter and improve airflow
  • NVIDIA SLI Ready
  • Double Ball Bearing fan for exceptional reliability and quiet operation
  • Heavy-duty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP (Over Current Protection), OPP (Over Power Protection), and SCP (Short Circuit Protection)
EVGA SuperNOVA 850 G2 - power supply - 850 Watt
Power supply - internal
80 PLUS Certification
80 PLUS Gold
3.63 kg
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
850 Watt
Output connectors
1 x power 24 pin ATX , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 2 x 6 pin PCI Express power , 10 x 15 pin Serial ATA power , 4 x 4 PIN internal power , 1 x 4 PIN mini-power connector
15 cm x 18 cm x 8.5 cm
10 years warranty
Input Voltage
AC 100-240 V
Frequency Required
50/60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
850 Watt
Output Current
+3.3V - 24 A , +5V - 24 A , +12V - 70.8 A , +5VSB - 3 A , -12V - 0.5 A
Efficiency
90% (115VAC) / 92% (220-240VAC)
80 PLUS Gold
MTBF
100,000 hour(s)
Over current protection, over voltage protection, overpower protection, SLI ready, undervoltage protection, short-circuit protection, dual ball bearing cooling fan, Intel 4th-gen CPU (Haswell) compatible
TUV, BSMI, CB, FCC, RoHS, WEEE, cTUVus, RCM
10 years warranty
Limited warranty - 10 years
50 °C
15 cm
18 cm
8.5 cm
3.63 kg
Scroll to top
