Click to visit BT.com
BT.com
Wishlist
EVGA 650W SuperNOVA NEX650G 80+ Gold Fully Modular Power Supply
Quicklinx: 8DWSWS00
Mfr#: 120-PG-0650-GR
The EVGA SuperNOVA NEX750 and NEX650 Power Supplies are here in Gold rated options. Designed with enthusiast needs in mind the NEX series is the best choice to power next generation enthusiast computers. Combining 750W or 650W of continuous power with exceptional performance, stunning efficiency, and cutting-edge design and features, the NEX series power supplies are what you need to take your system to the next level.
Key Features
  • 80PLUS Gold certification in pending, with up to 90% efficiency under typical loads
  • Fully Modular to reduce clutter and improve airflow
  • Highest quality Japanese brand capacitors ensure long-term reliability
eVGA SuperNOVA NEX650 Gold - power supply - 650 Watt
Power supply - internal
80 PLUS Certification
80 PLUS Gold
3.85 kg
Input Voltage
AC 100-240 V
Power Capacity
650 Watt
Output connectors
1 x power 24 pin ATX , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 1 x 6 pin PCI Express power , 9 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 1 x 4 PIN mini-power connector
15 cm x 18 cm x 8 cm
5 years warranty
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Power Capacity
650 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V1 - 20 A , +12V2 - 20 A , +12V3 - 20 A , +12V4 - 20 A , +5VSB - 3 A , -12V - 0.8 A
Efficiency
90%
80 PLUS Gold
Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, dual ball bearing cooling fan
UL, TUV, C-Tick, BSMI, cUL, CB, CCC, FCC, RoHS
5 years warranty
Service & Support Details
Limited warranty - 5 years
50 °C
15 cm
18 cm
8 cm
3.85 kg
Resources
The following resources are available for the EVGA 650W SuperNOVA NEX650G 80+ Gold Fully Modular Power Supply
