BT.com
Wishlist
eVGA 600B Bronze - Power supply ( internal ) - ATX12V - 80 PLUS Bronze - AC 100-240 V - 600 Watt
Delivery
Standard Due date unavailable
With price and performance in mind, the EVGA 600B is the best value power supply for your next build on a budget. With 80 plus bronze standard, over 80% efficiency under typical loads, the EVGA 600B is a great choice. Combining 600 W of continuous power and single +12 V high AMP rail design, gain maximum power and efficiency while staying protected with a series of multiple safety protections all bundled into one!
EVGA 600B Bronze - power supply - 600 Watt
Power supply - internal
Specification Compliance
ATX12V
80 PLUS Certification
80 PLUS Bronze
2 kg
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
600 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 8 pin PCI Express power with detachable 2 pin section , 3 x 4 PIN internal power , 6 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
15 cm x 14 cm x 8.5 cm
3 years warranty
ATX12V
PSU Form Factor
ATX
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
600 Watt
Output Current
+5V - 20 A , +3.3V - 24 A , +12V - 49 A , -12V - 0.3 A , +5VSB - 3 A
Efficiency
85%
80 PLUS Bronze
Power cable 1.2 m
Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail, Intelligent Fan Control Technology
UL, TUV, FCC, RoHS, cULus
Limited warranty - 3 years
15 cm
14 cm
8.5 cm
2 kg
Scroll to top
