BT.com
Wishlist
EVGA 1500W SuperNOVA NEX1500 Classified Power Supply
The Ultimate Enthusiast Power Supply!
Delivery
Standard Due date unavailable
OCZ Technology 1500W SuperNOVA NEX1500 Classified Power Supply
The EVGA SuperNOVA NEX1500 Classified is the ultimate enthusiast power supply. Designed to support the toughest hardware, the EVGA NEX1500 Classified supports features like SuperNOVA enthusiast software control, overclock mode that increases the maximum power output up to 1650 W, and fully modular, individually sleeved cables.
You can also count on EVGA to provide the utmost reliability and performance, with 100% Japanese capacitors and a durable ball bearing fan. The NEX1500 Classified is designed from start to finish to be the excellent choice for today's most demanding high-end computers. Get to the next level with the EVGA NEX1500 Classified power supply!
  • Continuous Power: Trust EVGA to label all of our power supplies in Continuous Power, the steady power a PSU can output continuously, rather than the amount delivered at its short-lived peak.
  • SuperNOVA Software: Exclusive SuperNOVA software allows you to monitor voltage, current drawn on each rail, power used, efficiency, allows you to change the fan profile and even adjust the +12V rail!
  • Single OR multiple 12V Rails: No longer will you have to toil over the decision of choosing a single or multiple rail PSU; the NEX1500 Classified lets you switch modes as you please.
  • Fully Modular, Individually Sleeved: EVGA delivers the highest quality cables possible, with individually sleeved cables and a fully modular design for optimal cable management and the best looks. On top of that EVGA supplies a massive 12AWG premium power cable!
*230 VAC Required for OC Mode
EVGA SuperNOVA NEX1500 Classified - power supply - 1500 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V / EPS12V
80 PLUS Certification
80 PLUS Gold
3.85 kg
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1500 Watt
Output connectors
1 x power 24 pin main output , 2 x power 8 pin EPS12V , 16 x 8 pin PCI Express power with detachable 2 pin section , 3 x 6 pin PCI Express power , 12 x 15 pin Serial ATA power , 8 x 4 PIN internal power , 2 x 4 PIN mini-power connector
15 cm x 20 cm x 8 cm
10 years warranty with product registration
ATX12V / EPS12V
Input Voltage Range
AC 100 - 240 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1500 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V1 - 20 A , +12V2 - 20 A , +12V3 - 20 A , +12V4 - 20 A , +12V5 - 20 A , +12V6 - 20 A , +12V7 - 20 A , +12V8 - 20 A , +5VSB - 4 A , -12V - 0.8 A
Efficiency
90%
80 PLUS Gold
Overheat protection, over current protection, over voltage protection, overpower protection, SLI ready, undervoltage protection, short-circuit protection, eight 12V rails, ball bearing cooling fan
UL, TUV, C-Tick, BSMI, cUL, CB, CCC, FCC, RoHS
Limited warranty - 10 years
50 °C
15 cm
20 cm
8 cm
3.85 kg
Resources
The following resources are available for the EVGA 1500W SuperNOVA NEX1500 Classified Power Supply
Scroll to top
