BT.com
Wishlist
EVGA 1000W SuperNOVA 80 Plus Modular Gold PSU
EVGA 1000W SuperNOVA 80 Plus...
£158.64
£158.64
Add to wishlist
Delivery
Standard Due date unavailable
Ready for 4th Generation Intel Core Processors (C6/C7 Idle Mode)
The EVGA SuperNOVA 1000 G1 has arrived! This power supply is 80 Plus Gold Rated, offers 1000W of continuous power, exceptional efficiency and is fully modular. Not to mention, a first class 5 Year EVGA Warranty. Designed with enthusiast needs in mind the EVGA SuperNOVA 1000 G1 power supply is the best choice to power this and next generation enthusiast computers. Take your system to the next level and power up with the EVGA SuperNOVA 1000 G1!
Cable Length
  • ATX CABLE 1x 600mm (m)
  • EPS CABLE 2x 600mm (m)
  • PCIE CABLE 2x 600mm, 750mm (m) 4x 600mm (m)
  • SATA CABLE 3x 550mm, 650mm, 750mm (m)
  • FOUR-PIN PERIPHERAL CABLE 2x 550mm, 650mm, 750mm (m)
  • FLOPPY CABLE 1x 100mm (m)
  • AC POWER 1x 1500mm (m)
This product comes with a 5 year limited warranty with registration within 30 days of purchase.
EVGA SuperNOVA 1000 G1 - power supply - 1000 Watt
Power supply - internal
80 PLUS Certification
80 PLUS Gold
3.63 kg
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1000 Watt
Output connectors
1 x power 24 pin ATX , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 6 x 8 pin PCI Express power with detachable 2 pin section , 2 x 6 pin PCI Express power , 9 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 2 x 4 PIN mini-power connector
Cooling System
135mm fan
15 cm x 20 cm x 8.5 cm
5 years warranty
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1000 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V - 83.3 A , +5VSB - 3 A , -12V - 0.8 A
Efficiency
90% (115VAC) / 92% (220-240VAC)
80 PLUS Gold
MTBF
100,000 hour(s)
Cooling System
135mm fan
Over current protection, over voltage protection, overpower protection, SLI ready, undervoltage protection, short-circuit protection, dual ball bearing cooling fan, Intel 4th-gen CPU (Haswell) compatible
UL, TUV, BSMI, CB, FCC, RoHS, WEEE, RCM
5 years warranty
Limited warranty - parts and labour - 5 years
50 °C
15 cm
20 cm
8.5 cm
3.63 kg
Resources
The following resources are available for the EVGA 1000W SuperNOVA 80 Plus Modular Gold PSU
Scroll to top
