BT.com
Wishlist
Euroscreen Draper Connect Manual Pull Down 16:9 Format 86"
Euroscreen Draper Connect Manual...
£179.22
£179.22
Add to wishlist
Delivery
Standard Due date unavailable
Connect is a basic compact screen which is very easy to install. The case is made of steel. It can be mounted either on the wall or in the ceiling and is attached to the wall/ceiling with one screw at each end of the case.
Euroscreen Connect Wide Format - projection screen
Projection screen
Placing / Mounting
Ceiling mountable, wall mountable
Projection Image Size
190 cm x 107 cm
Aspect Ratio
16:9
Screen Surface
Matte White
209 cm 165 cm
7.4 kg
Projection screen
Placing / Mounting
Image Width
190 cm
Image Height
107 cm
Screen Surface
Matte White
Aspect Ratio
16:9
Viewing Angle
180°
209 cm 165 cm
7.4 kg
Scroll to top
